+Video+ Help with weird sound from tranny.
Old Nov 10, 2006 | 10:01 PM
joon's Avatar
you can hear like an ugly rattling noise. can it be the tob..? things is that its new. it just sat on the tranny/on the floor for like 6 months when the car was down.
http://www.youtube.com/watch?v=SwhQ0dVuk-o
listen carefully.
Old Nov 11, 2006 | 01:05 PM
90GSXDan's Avatar
Does it go away when you push the clutch in? If it does, then its definitely the TOB.
Old Nov 11, 2006 | 03:28 PM
Kee1pride's Avatar
might be your balance shafts
Old Nov 12, 2006 | 11:02 AM
superflyevo's Avatar
deff the tob
Old Nov 12, 2006 | 08:48 PM
joon's Avatar
I think its partially TOB. i risked it on saturday, and headed from LA to T.J. Once i got to the rest stop at san diego, i noticed my car feeling weird. "the heck", i said, and on we went....frist gear was jumping, i lost reverse, 5th gear wouldnt go in all the way. I exited the first exit, and pulled over at a del taco, near camp peddleton. Went to a chevron, bought some gear oil, and added it, thinking that cant be it. i added the oil, started the car, first gear grabbed like butter, no reverse. SO i said, "the heck with it" again, and headed back home. once i got home, i got reverse back, after a little stuggle. Now, is it possible that i grinded some gears down? its starting to make the same noises. i guess what i should do is throw the oem clutch in, and send it to the dealer to get it checked out. i have 38000 miles on the car, bought it with 30000.
what do you guys think?
Old Nov 12, 2006 | 08:54 PM
DevilsEvo666's Avatar
Either a tob which i highly doubt...or its most likely an internal tranny issue...My 89 prelude si made the exact same noise..and later i found out after a close inspection that indeed it was an internal bearing inside the tranny...! Hopefully thats not the case here but thats what it does sound like to me....Good Luck!
Old Nov 12, 2006 | 09:39 PM
joon's Avatar
yeah, well i think, im just going to go ahead, and remove the tranny and inspect it. if anything i might get a new used one, and replace clutch and all seals/rings. I think i need a new axle too. This car is making me waste money that i dont have!
This really sucks, but thanks to all of you guys for the support
elick
Future Lancer / Evo Models
Feb 20, 2011 08:24 PM
daisaw1219
Oct 13, 2010 08:17 PM
Davethewave
Mar 22, 2009 12:32 PM
EvoDom
Feb 3, 2009 07:48 PM
Jersey Dino
Oct 26, 2006 02:50 PM
