Broken rod (crower)
Old Nov 25, 2006 | 09:24 AM
  #61
got boost??'s Avatar
Originally Posted by CO_VR4
Your pictures suggest to me that you dropped the head of a valve into the cylinder. Your pictures show damage to the cylinder walls which are caused by (uncompressable) foreign object(s) bouncing around in the cylinder. There is not enough room for the engine to rotate to TDC with the valve head broken off in the combustion chamber. Something has to give -- either the cylinder head and/or the top of the piston. A hundred or so revolutions with the valve head in there broke the piston, and then what was left of it caught on the lower end of the cylinder bore and the crank powered it through the side of your block. That's my guess How does the combustion chamber for that cylinder look? Beat to crap? Missing a valve head? If it is, what caused it? Could be metal fatigue, but valve float is also a common cause, when the engine is overreved and the springs are not heavy enough to maintain contact with the cam. The valves get pulled up into the head by the spring after the cam has spun away from contact, and slam into the seat. After a few of those events the spring pulls the valve stem off the head, leaving the head in the combustion chamber. Can you get pics of the cylinder head?
Well, valve problem, thats for sure, why it broke, not a clue, but it caused a lot of damage.
Don have pics of the chamber, it's already being fixed but for sure i'll take a pic to the broken valve and the rest of the piston laying down in the oil pan.
At least i'm a bit more relaxed cause it wasnt a tuning problem
Thanks everyone for your interest.
Cheers.
Old Nov 25, 2006 | 07:40 PM
  #62
barneyb's Avatar
I was reading a car book today and came upon where they were discussing valve float. I had always heard about valve springs getting weak but I never knew what caused this. According to what I was reading, when a valve floats the valve spring gets hot, hot to the point that it can glow. I'm still not quite clear why this is. Anyway, the valve with the weakest spring to begin with is going to float and then if it gets hot like they say, I can see how things could quickly go down hill from there.
R/TErnie
26
Sep 23, 2017 04:42 PM
hutch959
Mar 8, 2016 05:59 PM
extremepsi
Feb 2, 2016 06:22 PM
d613
Jul 27, 2011 10:09 AM
3gEclipseTurbo
28
Jun 17, 2010 09:00 PM
