Broken rod (crower)
Old Nov 20, 2006 | 08:43 AM
got boost??'s Avatar
Broken rod
Sorry guys, want's a rod, just a cutted valve head, a distroyed block and piston.
Rod is still in one piece.
Yes they were CROWER rods, i'm impressed how much abuse it handled.
Thanks.
Old Nov 20, 2006 | 08:45 AM
joeymia's Avatar
12.5-13 AFR is insanely lean I find it hard to believe that it wasn't knocking
Old Nov 20, 2006 | 08:46 AM
okevolutionVIII's Avatar
Try Oliver rods or Groden rods from Buschur.
Old Nov 20, 2006 | 08:47 AM
110 octane fuel
EVOLVEU's Avatar
I agree, 11.3 and below could be considered conservative.
Old Nov 20, 2006 | 08:49 AM
EVOLVEU's Avatar
Originally Posted by okevolutionVIII
110 octane fuel
I just read this, nm.
Old Nov 20, 2006 | 08:52 AM
Exactly, 110 octane fuel with alky injection, so AFR's were just fine.
BTW, we were racing 1/8 mile and redline at 7500 RPM's.
Oliver rods??? how much HP can them hold???
thanks.
Old Nov 20, 2006 | 08:54 AM
BTW, we were racing 1/8 mile and redline at 7800 RPM's.
thanks.
They have held 903whp on an AMS built car. I'm sure they will hold more easily.
Old Nov 20, 2006 | 09:00 AM
240Z TwinTurbo's Avatar
What area of the rod failed and what was the mode of failure? Pics? I have Carillo's in my RB26 and hope not to have any issues. I have heard nothing but good things. BTW, there are several different choices of rods from Carillo so make sure which ones were sold to you.
Old Nov 20, 2006 | 09:04 AM
eficker's Avatar
HP doesn't break rods, detonation does. During detonation or knock, cylinder pressures are many times what they are during normal combustion regardless of what hp numbers you are putting down.
A million things could have caused it, a hiccup in the fuel system, or a dust hitting the maf, but since it seemed to break all at once, its pretty obvious it was not a strength of materials problem, but more of a pre-ignition problem.
That is pretty lean, but i have seen it done before. Only on full race cars though, and you do have to be pretty right on about timing to not cause an issue.
Old Nov 20, 2006 | 09:07 AM
bigyellowevo's Avatar
Where area of the rod did the breakage occur?
Old Nov 20, 2006 | 09:11 AM
WOW, 903whp, i think that would be enought for my setup
Coudn't find oliver rods at buschur's page and as you describe them, i'd like to buy those, i only found groden rods and BTW whats the difference on the 6 bolt and 7 bolt???
Rod failed exactly in the middle from center to center and BTW they were CROWER rods, not carillo. A friend with a 450WHP setup on a civic had a carillo rod failure.
Old Nov 20, 2006 | 09:12 AM
Spec'd's Avatar
Sorry about your motor.
What about Pauter Rods ?
Old Nov 20, 2006 | 09:15 AM
AutoMotoSports's Avatar
We have pushed Oliver rods to over 1041 WHP on an evo.
You can buy them right from Us if you like
I think that there is something else going on with the car though. As was stated. You did not over power the Crower rod (we have pushed them to well over 800) something else is going on
Eric
Old Nov 20, 2006 | 09:25 AM
I know hp doesnt break rods, in fact torque does, high reving and excesive cilynder pressure.
Well, there was no knocking showed in the MSD knock alert, so i assume a strength problem.
But nevermind, i'm not trying to flame anybody. **** happens and this was my turn.
No i junst want to buy better rods.
Thanks.
