best cam settings for my 2.0 with GT37R
Faisal,
I don't think that it would make that much of a diff playing with the cam settings, maybe a 500rpm here or there. We just leave them at zero and rev it higher.
However, do a search cause there was a whole bunch of discussion on the subject a while back! Allot of testing too!
Originally Posted by 11secEVO7
can anyone suggest some settings to try?
Should we assume the cams are the HKS 272s you mention in your signature? If so, I suggest a different set of cams altogether.
Originally Posted by wspy
Faisal,
Originally Posted by Ted B
For which cams? They are not all timed equally!
Lol...well I've had these cams for close to 2 years but since I was still doing upgrades I never bothered to set them. They were just left on zero. But now..coming to the end of the project so to speak, I would like to try a setting on it to see if it makes any difference at all...
Out of curiousity, what cams would you recommend?
Originally Posted by Rez90
when the hell does your turbo spool?
Full boost comes in around 5500rpms(have to check back the data to confirm this but I believe this is where it's at..cant always look while I'm driving and someone else does the tuning so he has all the logs) and goes up to a redline of 8500rpms.
But as I said....no noticeable difference between the 35R and the 37R.
so I'm perfectly satisfied.
Yes.HKS 272's
03RRVIII
Jun 10, 2008 01:54 PM
