Differential fluid
Old Nov 22, 2006 | 08:52 AM
ihatepotholes's Avatar
Differential fluid
i did search but couldn't find answers. does differential fluid fluctuate? because i checked out all the fluid today, differential fluid is at min/low. i only have 2900miles on the car, i couldn't find any leaks. only thing i can i think thats different is that my injen intake filter is leaned on the differential fluid container, and intake vibrates all the time. could that be the problem?
Old Nov 22, 2006 | 08:59 AM
tripperfx3's Avatar
Say what!? Diff fluid container!? I dont know of anything like that on the Evos... Maybe your ACD...?
Old Nov 22, 2006 | 09:16 AM
i guess so, its the pink fluid right next to the intake
Old Nov 22, 2006 | 09:33 AM
sparky's Avatar
I think it´s the ACD fluid, uses ATF SP II, maybe you should check level when fluid is hot, then if it´s low....top off to upper level.
Old Nov 22, 2006 | 09:40 AM
^ thanx man, ATF is the maker? is it what mitsubishi use?
Old Nov 22, 2006 | 09:42 AM
is it suppose to be consumed like that tho?
Old Nov 22, 2006 | 09:44 AM
PessimiStick's Avatar
My ACD fluid fluctuates quite a bit. I thought it was temperature related, but I've seen it vastly different while warm and cold. I have no idea what the deal is. =D
My current theory is that it's very sensitive to being level, causing it to read differently based on where you are parked.
Old Nov 22, 2006 | 09:46 AM
tweakdsm's Avatar
Use OEM fluid. Get it from Local Mitsu dealer. Also you can look it up in the manual.
Old Nov 22, 2006 | 09:51 AM
thanx for all the helping guys, im gonna try to park at a more flat surface to see wether if it's low or somthing else... but how often do u have to add em anyway?
Warrtalon's Avatar
It's called Diamond SP III ATF fluid, and it's only for the ACD. It does not get consumed, and the Mitsu dealer should have plenty of it in 1qt containers.
Old Nov 22, 2006 | 09:53 AM
Warrtalon's Avatar
You replace the fluid when doing the trans/clutch if the person doing the work doesn't know how to remove the trans without disconnecting the ACD line. It doesn't need fluid added. If fluid needs to be added, then there is a big problem, or it was never filled.
Old Nov 22, 2006 | 10:04 AM
thanx for the help, the car drives fine, i haven't noticed any difference... so what would happen to the acd?
Old Nov 22, 2006 | 10:28 AM
RazorLab's Avatar
It will be close to min after driving and the car is warm. It should be at full or a little above after it's been sitting around or cold.
Old Nov 22, 2006 | 10:44 AM
dude! i love u man! not in a homosexual way, but thanx a whole lot. i just check it again, it's only about 1 mm below max. so how did u find out about it?
Old Nov 22, 2006 | 10:50 AM
RazorLab's Avatar
I believe it states that in the owners manual.
