Head noise need help
Old Nov 22, 2006 | 07:06 PM
Paul Nelson's Avatar
So at about 3000rpm and up i have a loud tapping noise from the head.
1) i put new lifters in today and it went away for a bit and came back
2) the old lifters had worn the ball part and metal shavings had gotten traped in the little oil hole all the lifters were the same wear.
so we cleaned them all out and installed the new lifters from JAM
3) put 20/50 wt oil just to see if that would help but no luck
4) the noise gets louder as the car runs longer and is rpm dependant ( 3k and up to 5k)
ive been working with my mechanic and jackson machine to try to figure out the problem but to no luck
next step is a leak down test to see if there is a bent valve but whats weird the car idles perfect and make lots of power.
any help would be awesome
Old Nov 22, 2006 | 07:20 PM
DRFTKNGG's Avatar
Hows the oil pressure?...20/50 W would make it worse. Change that stuff out. 10/30 I would say you have a oil gallie plugged up and it's not letting the lifter...lifters, pump up. Metal shavings are from shearing. Something isnt getting lubricated.
Recent cam shaft install? Is this after any work has been done under the valve cover recently?
Old Nov 22, 2006 | 07:23 PM
had 10/30wt and went to 20/50 after jackson machines advice
this is a new build mods are in my sig were putting a oil gauge on it friday to see what were pushing
Old Nov 22, 2006 | 07:36 PM
whats odd is all of the lifters had the same shearing in the cup?
Old Nov 22, 2006 | 07:54 PM
scottatyamaha's Avatar
Are the cam bearing caps torqued to spec? 15/pounds??
Old Nov 22, 2006 | 08:40 PM
ill have to check and see. i would asume they are. would that cause the lifter not getting enough oil?
Old Nov 22, 2006 | 09:43 PM
Jim_Patterson's Avatar
sounds to me like an oil related problem.
