Best street clutch for around $500
My clutch is wasted, its from me doing holeshots. My car has 8k miles on it. Anyway I need a clutch at a good price. PM me if you like. Yes I have searched!
Thanks,
Kyle~
Thanks,
Kyle~
my clutch just went at 8k also. I bought an ACT MB7-HDSS with the prolight flywheel. Should have it in next week some time. I did a lot of searching and decided this would be the best setup for me. It is a very tough decision as there are so many different clutches out there. I had an excedy twin in my 03 and didnt want to go with a twin disc this time around. Good luck! BTW i got it from Chris at nolimitmotors. They also sell excedy clutches at a great price also if you decide to go that route.
What is decel noise?
I use an ORC409D super single that is a matched set with flywheel, metal disk, pressure ring, aluminium cover and release bearing. I am not sure how much they cost in the US but they are about $650 with the current yen rate over here. Yes, I realize this is $150 more than you stated but you will be receiving more than just a clutch. The setup is rated for 400whp. I use the model without dampening springs because the dampeners normally fail while the clutch disk has lots of life left on it!!
A replacement disk is about $250.
I have been using metal disk and multi-disk setups for years and I have never encountered "decel noise".
Clattering between shifts is no big deal unless you drive with the clutch pedal at the floor all day long.
