Case Study # 151 - IX Evo with Intake and MBC makes great power
Old Dec 3, 2006 | 11:06 PM
DynoFlash's Avatar
This car ran really well
2006 IX MR
Injen Intake
Forge Unos MBC
Walbro Fuel pump
100% stock exhuast
Custom Dyno Flash tune
21 psi peak 93 octane pump gas
Old Dec 3, 2006 | 11:11 PM
thisxguy's Avatar
intake huh. do you have an estimate on a MBC (@21psi) on a stock ix does? i wonder how much that intake added.
Old Dec 3, 2006 | 11:14 PM
joshesh's Avatar
how much do all those mods add up costing?
Old Dec 4, 2006 | 12:33 AM
Wicked MR's Avatar
www.lancershop.com for the parts and the flash is something like 200 or so.
Old Dec 4, 2006 | 02:08 AM
spyderx's Avatar
stock exhaust, completely?
Wow, I may just put the stock cat back on!!!
Old Dec 4, 2006 | 04:31 AM
meanmud's Avatar
even if it had a TB and Test Pipe, that would be one of the Strongest IX's dynoed
324whp/348lb.ft. = 430bhp/462tq??
Old Dec 4, 2006 | 05:13 AM
C6C6CH3vo's Avatar
At 21psi, those IX turbo's move the same air as a VIII turbo at 25psi. Add this to the other 9 qualities and those results aren't surprising at all, still impressive though.
Whats that equivalent to on Mustang?
Glad I didn't waste any money on a catback, definatly have to gut out the muffler check valve however
Old Dec 4, 2006 | 05:27 AM
PPI's Avatar
PPI
lol, worthless without baseline numbers. Those numbers seem to be more inflated than Dynojet....
Old Dec 4, 2006 | 05:29 AM
Soon2BEVO's Avatar
Definitely not true.
Old Dec 4, 2006 | 05:40 AM
SlowCar's Avatar
325/350@21psi.......
this guy made 360/400@25psi
https://www.evolutionm.net/forums/sh...d.php?t=234800
will be nice to see a before/after dyno plot
Old Dec 4, 2006 | 09:32 AM
Kee1pride's Avatar
dynoflash forums = locked?
Old Dec 4, 2006 | 07:33 PM
C6C6CH3vo's Avatar
OK:
At 22psi, those IX turbo's move the same air as a VIII turbo at 25psi.
Well if it's not true than what is ?
Old Dec 4, 2006 | 07:48 PM
nikkadanny's Avatar
dang nice numbers!
Old Dec 4, 2006 | 09:12 PM
Soon2BEVO's Avatar
OK:
Thats wrong. They have a larger compressor housing which is helping it but its not moving any more air than a 2005 turbo. Its the same compressor wheel, same turbine wheel, same turbine housing (10.5). The IX's have more aggressive intake cams with higher lift, they have MIVEC, they have better designed heads to allow more timing. Many factors. Its not an EVO8 with a different turbo. I dont know where you people come up with these ideas.
Old Dec 5, 2006 | 05:08 AM
C6C6CH3vo's Avatar
This aint an idea engineerboy: The compressor housing was increased in order to keep up with increasing demands and loads with the mivec sytem. The evo IX comsumes more air period, and would not be able to do so with the VIII compressor.
The turbo itself isn't the cause of the IX's power, niether is any other single changed IX component, it's the whole system alltogether
