TBE+02 housing=boost cut?
Old Dec 7, 2006 | 09:43 AM
Jersey Dino's Avatar
I installed my TBE and drove the hell out of the car. felt great. I am going to get tuned next week. so I installed my 02 housing and BR cone filter. the car feels great, but I am hitting boost cut in 3rd gear at WOT. I can go through 1st and 2nd fine, but around 5000-6000rpm it hits boost cut and bucks. I dont remember the number for the code but it was an overboost code. I dont know how many PSI its running yet, my gauge was supposed to be hear yesturday. Stock tune, stock boost control. Im guessing its from the 02 housing. Just wondering if its normal to experience this without a tune or boost controller
Old Dec 7, 2006 | 09:50 AM
Boltz.'s Avatar
FCOTM Winner
The o2 housing along with the open element filter will induce more boost, combine that with winter weather and I could easily see you hitting boost cut.
I don't know what it is with the stock evo9 ecu programming but they're retarded until flashed for some reason.
Old Dec 7, 2006 | 09:55 AM
AndyBandy's Avatar
sounds like you need a tune
Old Dec 7, 2006 | 10:03 AM
yeah. I am going to get a tune. I did the filter and 02 housing at the same time, so I dont know if it would behave better with the stock filter back on. but it has been cold so boost would be inclined to spike and increase. I am going to pick up a gauge tonight. so we'll see what its doing. but I am also going to install my MBC so control it a little better then tune next week hopefully. does anyone know what the stock boost cut is set at?how many PSI? I know its a value that has to be sustained for a certain length of time. like a second of constant pressure or somethign like that.
Old Dec 7, 2006 | 10:04 AM
wz1999's Avatar
You need to tune your boost maps.
Old Dec 7, 2006 | 10:06 AM
Jasil's Avatar
E-flash from TTP or Jestr 50$ dollar fix + the $90 Tactrix cable.
Old Dec 7, 2006 | 01:20 PM
RenoEvo's Avatar
i have a catless tbe and o2 housing and I'm untuned. No boost cut or any problems at all. I wonder if the intake is messing with your car
Old Dec 7, 2006 | 05:21 PM
TTP Engineering's Avatar
Thanks...
The boost cut is MAINLY from the conical filter and cold weather that make the MAF sensor think its injesting more air than it actually is. Tuning will take car of that. You are likely running really rich.
Old Dec 8, 2006 | 07:29 AM
thats what I was kinda thinking might be the case. I finally got my boost gauge so I am going to set it and drive it nicely for the weekend. Im getting tuned monday. so I will let you know how I make out. thanks guys
evoviiihan
10
Oct 22, 2016 10:00 PM
fit4130bmx
Feb 29, 2012 05:14 PM
iluvmydsm
Jan 24, 2011 06:46 PM
amsevokid
21
Nov 29, 2010 09:47 AM
rudy91889
Jun 4, 2009 02:52 PM
