Spool of 67mm+ T4 turbos?
Old Dec 7, 2006 | 10:42 AM
Po' Kid's Avatar
1: About what RPM do these turbos spool (moderate full boost - 15 to 18 PSI) on 2L engines (Ill even take stroker info)?
2: Anyone who has driven or owns a car with a larger turbo, how responsive would you say it is?
3: Any dyno graphs showing torque, HP, and RPM?
I am trying to find graphs of these large turbos on smaller engines to see about when they will spool on my street / strip MR2. I want something that will spool to moderate boost levels by around 5500 RPM, and revving to likely around 9k.
Thanks.
I will do some more searching around, but I havent been able to find much really.
Old Dec 7, 2006 | 10:48 AM
240Z TwinTurbo's Avatar
SR20DET'd RX7
67mm P-trim .58 a/r tangential housing
~5200rpm 20psi
Jasil's Avatar
So far there has been no proof that T4 is worth the loss in spool over a T3 in a 67mm wheel. The only info I could find was on Rx-7's A-Spec found a additional 10-20whp by going to a divided T4 over a standard T4 or T3 with better transient and minimal spool up loss.
700whp capable the 37R is for you IMO.
Old Dec 7, 2006 | 10:59 AM
Po' Kid's Avatar
Im looking for 500 on 91 pump and around 700ish (for a 9.99) with meth injection and possibly some spray (no race gas), which is why I will need the most efficient hotside possible I think. Thanks for the info! Anyone else?
*edit*
Found a thread with a few guys talking about full boost (much higher boost levels than I would run on the street) at the high 5k range, so I guess with a medium sized T4 housing Id be right around the 5500 mark for spool with the 66mm full T4 Im looking at.
Old Dec 7, 2006 | 02:31 PM
Paul Nelson's Avatar
Ill have dyno #s soon!
ITOzann
Oct 25, 2012 10:11 AM
T6
25
Feb 27, 2012 08:01 PM
94AWDcoupe
May 29, 2011 10:22 AM
JamaicanEvo
Feb 16, 2010 05:40 PM
donour
May 25, 2006 03:53 PM
