EVO Green/20g-LT airflow numbers
Old Dec 13, 2006 | 01:38 PM
  #91
yellowEVO21's Avatar
Originally Posted by 4cdndctn
I had a 20gLT installed at 1320 Performance in NJ then tuned Sean Ivey.
I have your basic Buschur stage 4 plus some other peripherals but no internal work done.
I went in with a car with felt moderately quick pushing around 365whp and 340lb/ft on Pruven's dyno (27psi/93 octane)
I left with a car that felt fast and responsive pushing around 414whp and 393lb/ft on Pruven's dyno. The car was consertively tuned for road course with a map that showed almost no knock, with the count only hitting '2' one time with a few '1' showing and mostly '0' showing (29psi/93 octane).
As a road course driver, I was thoroughly impressed with spool and ability to control the boost with my right foot.
I never thought that as the Evo would spool, it would chirp the tires but much to my surprise, it did around 3900 rpm.
The new tune held power until about 6800 then dropped fast at 7200 - I have 264/264 cams btw.
All in all, highly recommend for street application, road course and 1/4mi depending on driving style.
were you running meth injection or alky?
Old Dec 13, 2006 | 01:44 PM
  #92
mrdevo's Avatar
So you went from stock 05 turbo to the lt and gained 49whp peak and 53ftlbs peak with 2 more psi. How much better is the power held over the stocker near redline? I know it should n't die off as bad but I'm curious if there were gains more than the peak after redline. Some 272 or 280 cams could wake your car up as well. Thanks for the info.
Old Dec 13, 2006 | 01:47 PM
  #93
kjewer1's Avatar
Robert, that exhaust pressure chart is great to see! I have thought about logging exhaust pressure for several years now but never got around to it. I'm really tempted to now since I plan to be maxing out this turbo plus running nitrous, which doesn't increase manifold pressure, but will increase exhaust pressure further.
The drop off at 7200 in the case above may be due to the smaller cams, hard to say. If I get a chance to dyno friday we can see how it looks with 272s.
I too was surprised that rolling on it in first, at around 5k rpm or so it breaks the tires loose. It does it in second too but I think it's mostly the fronts. Looking at how steep the airflow curve is with the silencer out it's really no surprise, it practically looks like it's a Honder
Old Dec 13, 2006 | 02:04 PM
  #94
l2r99gst's Avatar
Robert,
First off, thanks for the data!
I'm curious as to why you were able to hold 30+ psi to redline (peak of about 34 psi), whereas when Kevin removed the source to the WG, it spiked.peaked at 30.1 and held 26 psi to redline, resulting in about 49lb/min of airflow (which we are led to believe is the max flow of the compressor).
Was your test done on stock cams or something? Just curious.
Eric
Old Dec 13, 2006 | 02:10 PM
  #95
MR. Birdie's Avatar
Well guys I just order the 20G-LT and other parts from Buschur. I'll update with you guys once everything is put on and tune.
Old Dec 13, 2006 | 02:30 PM
  #96
ForcedPerformance's Avatar
shorten the actuator arm LOTS.
I'm seriously getting of the internet now
Robert Young
Old Dec 13, 2006 | 02:35 PM
  #97
RazorLab's Avatar
Originally Posted by ONRAILS
no way in hell tt or ams's 50t kits will make 450whp on pump gas. let along break 400 on buschurs dyno.
a AMS 50trim kit made 310whp at only 17psi on a bay area mustang dyno that pretty much reads the same as buschurs.
If it's already making 310whp at girly 17psi....
Old Dec 13, 2006 | 02:47 PM
  #98
Pd1's Avatar
Pd1
Originally Posted by TTP Engineering
Catching the tail end, but is this equipped with an aftermarket actuator?
The unit we tuned and tested peaked 29.0psi, tapering to 19psi at 7500 on the factory supplied actuator by BR and Forge UNOS MBC cranked full tilt.
In our testing we cannot stress enough NOT to use this unit with a factory WGA as was provided.
Yes, Kevin is using the upgraded actuator from FP.
If you want to run this turbo at 29psi, you're right...you should get the upgraded actuator.
However, having run both the upgraded and stock actuator on my car, I find that the stock actuator provides a much smoother boost curve without the "hump" that's logged (by Kevin as well) while using the HP actuator running at ~22psi.
For the regular guy on the street who's not running race gas or meth, and especially those stuck on 91 octane, the stock actuator may be the right choice in order to maintain a smooth (and easily tunable) boost curve that won't go too high in 4th gear. My testing with no boost controller at all (looped vacuum line to WGA) resulted in peak boost pressures above 20psi in 50*F ambient temps. The increased resolution of boost control (at the pressures I'll be running ~<25psi) that the stock WGA affords me, coupled with the absence of boost-humpage, makes it the right choice for me.
  #99
Jeff_Jeske's Avatar
What size injectors are required for this nearly 50LBS of airflow on 100 octane? How about 23psi on pump?
Old Dec 13, 2006 | 03:06 PM
  #100
dxbevo9's Avatar
+++1
23 psi on pump..those are the numbers i wanna see
Old Dec 13, 2006 | 06:58 PM
  #101
TTP Engineering's Avatar
A HP actuator with less preload sounds like a better choice though.
Old Dec 13, 2006 | 07:31 PM
  #102
kjewer1's Avatar
At 12:1 650s are JUST enough (~98% IDC), but at 11:1 they won't cut it, 750s are the minimum. Assuming all of the usual variables of course for fuel SG, base pressure, etc.
Old Dec 13, 2006 | 07:41 PM
  #103
Pd1's Avatar
Pd1
I hoped so as well, which is why I adjusted my HP actuator to nearly zero preload and tested it again before swapping it out. This resulted in the same boost curve with the aforementioned "hump."
The only way I was able to achieve a "normal" boost curve (peaking around 22psi) was by installing the stock IX actuator.
Old Dec 13, 2006 | 07:43 PM
  #104
Pd1's Avatar
Pd1
I think this accurately answers Jeff's first question.
Running 23psi on pump gas, you can get away with running 660cc injectors at about 90% IDC.
Old Dec 13, 2006 | 07:53 PM
  #105
Jeff_Jeske's Avatar
Thank you both.
BTW does that exhaust gas pressure graph indicate that a 3" exhaust is being used to capacity?
