Evo IX IS there any point for the 20G-LT
Old Dec 10, 2006 | 05:43 PM
yellowEVO21's Avatar
rule of thumb, always put on full bolt-ons before you decide to upgrade your turbo...
i'd wait till you have your fmic, put in new cams, maybe run alky, and get retuned.....then decide if you STILL want to upgrade your turbo.
Old Dec 10, 2006 | 07:41 PM
JohnBradley's Avatar
Originally Posted by Bosshog
also, that is not an APS turbo kit - its ATP. APS stuff is top notch and not cheap! one of my friends has their twin turbo kit on his 350Z with forged engine - nice stuff
I think he got confused with the picture of the APS Subaru upgrade that is mysteriously on the Evo page. There is Agency Power also so maybe thats where the APS kit came from.
Old Dec 10, 2006 | 08:47 PM
kjewer1's Avatar
Originally Posted by thercpilot
Hi guys,
Would anybody know what is the flow of the stock Evo 9 turbo? Much more than Evo 8 stock turbo?
Thanks.
All of the information I have seen says that the 9 compressor wheel is the same as the eight, it's just the housing that is different. That would put max flow at the same level as an 8 turbo, 42 lbs/min.
Old Dec 10, 2006 | 08:49 PM
TeamTurtle's Avatar
High spool time is ideal for me. I drive a lot of city, and staying under boost gives me more miles per gallon.
Old Dec 13, 2006 | 03:03 PM
Danny23's Avatar
try looking into the 3076 turbo.
Old Dec 13, 2006 | 03:05 PM
kreionic's Avatar
Thats doing it the smart way. Those are the steps I am talikng.
Old Dec 13, 2006 | 03:10 PM
Frenchy4g63's Avatar
that would be a good choice of if you want quicker spool check out a 3071r
Old Dec 13, 2006 | 03:34 PM
MR. Birdie's Avatar
The 20G-LT is similar to 50 trim. The pervious post show that at 30psi peak boost it flow 48.9lb/min. I have a evo 9 with full bolts on and tune making 330whp/310lbs this is on straight 91 octane. I order the 20G-LT with buschur o2 housing and licp. I'll keep you guys update on the process, I'll also have the GSC s1 cams too.
Old Dec 13, 2006 | 04:14 PM
94AWDcoupe's Avatar
That should make a sweet combo.
Old Dec 14, 2006 | 02:18 AM
JustinTheGIMP's Avatar
if you want an ATP kit just go directly to their website at www.atpturbo.com
Old Dec 14, 2006 | 03:05 AM
El.BlueEvo9's Avatar
I was also thinking of buying a 20GLT. Now is the EvoGreen IDENTICAL to the 20GLT??? Meth Kit was also in my mind.Which one should be first??My Tuner at "TTP" had suggested to get the Meth, so I'm just basicly trying to get feedbacks on everyones thoughts. Right now I have a 3"Cat, Test Pipe & D.P., 0.2. Housing, W. Fuel Pump, Unos Forge Manual Boost C., Injen Intake & Upper IC. P., Exedy Twin H.D., and a Ecu Flash, and a AMS lower IC Piping in my hands that will be shortly installed. Thanks Everyone
Old Dec 14, 2006 | 03:24 AM
streetturbo's Avatar
Originally Posted by El.BlueEvo9
I was also thinking of buying a 20GLT. Now is the EvoGreen IDENTICAL to the 20GLT??? Meth Kit was also in my mind. If U guys could please help me in suggestions on witch one would benifit me more "FASTER" at the moment, and I guess safer??? My Tuner at "TTP" had suggested to get the Meth, so I'm just basicly trying to get feedbacks on what everyone thinks. Right now I have a 3"Cat, Test Pipe & D.P., 0.2. Housing, W. Fuel Pump, Unos Forge Manual Boost C., Injen Intake & Upper IC. P., Exedy Twin H.D., and a Ecu Flash, and a AMS lower IC Piping in my hands that will be shortly installed. Thanks Everyone
EvoGreen is identical to 20GLT just another name for the same turbo. Go with alky for sure if you want to max out a bigger turbo than stock.
Old Dec 14, 2006 | 03:27 AM
Thanks
Old Dec 14, 2006 | 05:26 AM
MitsuJoe's Avatar
I could be wrong although I thought...
stock 03 9.8 turbo could push somewhere around 35lbs
stock 03 turbo with the 10.5 could push somewhere around 37lbs
stock 06 turbo could push somewhere around 41lbs
I pulled this out of posts so it could be way the heck off.
Old Dec 14, 2006 | 06:48 AM
Jeff_Jeske's Avatar
Arrow
LOL.... I took that as a rip on the 3076!
If what they say is true.... 1LB is about equal to 11HP .....then I suspect those numbers are off. There isn't 40HP difference between the 05 and 06 turbos. But it really doesn't matter because neither are going to flow 49LBS.
Not sure you some of you realize how much power 49LBS is!
It would be interesting to see if a 9 with stock cams could use all the top end airflow that the Green/LT/50 trim could toss at it. Mivec tends to help on the stock snail but is a cam upgrade in order for a 9 with a bigger hair drier?
