clutch install!! HELP
Old Dec 12, 2006 | 04:45 AM
deadbeatrec's Avatar
ok so yesterday i spend the whole day in CT at Pruven. i first want to say thank you to John and Kenny (i think thats their names) for the great work and staying late because of a malfunction.
ok so heres the problem/question. just so u know, they installed a ACT MB7-HDSS clutch and pressure plate with a prostreet online lightened flywheel. so on the way home when comming to a slow stop i noticed a loud high pitch kinda noise. it sounds like someone was running there wet finger over a crystal glass. i only notice it when comming to a stop and the weird part about it is that the clutch can be ingaged or disengaged. and this is all without touching the breaks.
so i have ruled out squeeky breaks and i dont even know if its the clutch. i have absolutly no idae what the hell this noise could be comming from and i need your help guys and gals. i will see if i can get ahold of Pruven later but its kinda worring me a little. please if u have any coments on what it would/could be let me know.
ps. the car feels awesome, clutch feels awesome and i love the lightened flywheel.
pss. again want to thank Pruven.
Old Dec 12, 2006 | 05:53 AM
well no replys so far?
Old Dec 12, 2006 | 06:35 AM
MitsuJoe's Avatar
Running a wet finger over a crytsal glass...I am trying to think what that sounds like...
What are you and the car doing when it makes this noise? I need more details.
Old Dec 12, 2006 | 06:42 AM
think of a loud high pitch hum.
when the noise occurs its when im comming to a slow stop like at a stop light. like i said i can have the clutch pedal push to the floor and it not in gear and it will still make the noise. its weird.
Old Dec 12, 2006 | 06:43 AM
Smike's Avatar
Does the noise go away when you start braking?
As you describe it, it sounds like high perf. pads. Did you check all the squeal bars on the bads? Maybe one got bent somehow (or you have worn pads and its time to change)? Once those touch the rotor you get the sound off braking.
Old Dec 12, 2006 | 06:53 AM
no the sound does not go away when i touch the breaks.
what is a squeal bar?
Old Dec 12, 2006 | 07:03 AM
Smike's Avatar
Does it get worse?
If you look at a pad set (per corner) one pad will have a thin metal flang attached to it. When you wear the pads down to a point this flang will come in contact with your rotor and make a sqealing sound. Its a reminder that you have worn pads and you should change them soon.
If you look at the right pad in this pic (sorry not an Evo pad - but we have them too) you can see the wear bar)
Old Dec 12, 2006 | 07:04 AM
MitsuJoe's Avatar
It is possible they bent the back heat shield on the back of the rotor. I have done this before and may be making a similar noise.
Old Dec 12, 2006 | 07:07 AM
YellowEvo03's Avatar
I have that noise sometimes in my spec stage III clutch (six puck). It only happens when I am in stop and go taffic and am slipping the clutch alot slower than I usually do during medium/light traffic. As long as the clutch grabs hard, does not slip while in gear, and doesn't lock you out at high rpms, I chalk it up to the miserable driveability of an aggressive clutch.
Old Dec 12, 2006 | 07:26 AM
just took the car out and i think its the break pads, seem to me like it has been misaligned somehow.
its very low speed sound, and its not a so much screatching as it is singing. i really think its the breaks. i am going to take the wheel off and see what i can see.
Old Dec 13, 2006 | 04:27 AM
put it on the lift last night and noticed it was the dust sheild and it was bent. wow that thing was making a racket!!!
thanks for all the help.
Old Dec 13, 2006 | 05:01 AM
MitsuJoe's Avatar
Good for you! I like easy fixes and of course it is fun to be right sometimes.
Old Dec 19, 2006 | 07:07 PM
john breezy's Avatar
sorry about that man...glad it was an easy fix for ya
hope to see you in the spring for your turbo kit and tune, untill then enjoy
_JOhn@pruven
mrfred
Jun 15, 2015 06:26 AM
fightex
Jul 6, 2012 05:58 AM
Pal215
May 17, 2011 10:53 PM
Vivid Racing
Sep 13, 2010 11:49 AM
Alfriedesq
Sep 16, 2007 10:38 PM
