HELP no power to Fuel Pump car wont start
Old Dec 14, 2006 | 02:17 PM
BMWE30's Avatar
I have taken everything apart tested both stock and 255lb walbro they both work. I also checked and replaced the fuse under the hood with no luck where do i go from here i also have no power at the connection that plugs into the fuel pump housing?
Suggestions?
Justin
Old Dec 14, 2006 | 02:54 PM
BMWE30's Avatar
https://www.evolutionm.net/forums/sh...24#post3757624
Old Dec 14, 2006 | 03:02 PM
Gusl's Avatar
ar wont start
I had a similar problem with my car.
it turned out to be a blown fuse for the ignition.
Suggestions?
Justin
Old Dec 14, 2006 | 03:27 PM
C6C6CH3vo's Avatar
If you check all your fuses and they're good, here is the route the power goes
The relay location (2 of ther 3 relays) are for an 04 though
let us know what it was
Good luck
Old Dec 14, 2006 | 08:14 PM
GTREVO's Avatar
I couldn't find the fault with mine thus I wired the pump direct and it started...
Old Dec 15, 2006 | 02:09 AM
BoostN's Avatar
No chance you might have flashed the ecu did you? The immobilizer will stop the pump
Old Dec 15, 2006 | 02:34 AM
BMWE30's Avatar
I flashed the car like quite awhile ago i dont think that would be it but i will try anything.
Old Dec 15, 2006 | 02:59 AM
BoostN's Avatar
No, if you havent flashed it immediatly prior to the "no fuel" issue, then scratch that. It was a mistake I made accidently awhile back.
https://www.evolutionm.net/forums/sh...d.php?t=232996
Sorry, wish I could help more. But I did have a friend with that problem and it was the fuse posted above.
How many times has your ecu been disconnected? I hear after many times of pulling the harness pins can go bad and give you problems. Just a guess.
Old Dec 15, 2006 | 04:37 AM
C6C6CH3vo's Avatar
Power wont get to fuel pump unless engine is started via ecu and FP relay 2/3. I would jumper socket 2 to 1 with the relay 3 removed and do the same to 1 to 4 of relay 2, and then turn IGN to on. To see if you have 13vdc to pin 5 of pump, and go from there.
Possibilities:
1) Fuse (two I think play a role)
2) ECU
3) FP Relay 1
4) FP Relay 2
5) FP Relay 3
6) Wirining/bad contacts
Old Dec 15, 2006 | 07:01 AM
Bdub25's Avatar
Does the car crank over?? I'm having this problem with my car also.. My car cranks but wont start.. And i've checked the plugs and pump and still nothing.. But i have alot done to my car.. Standalone and all those goodies.
Old Dec 16, 2006 | 09:18 AM
BMWE30's Avatar
Ok guys i GOT it!! Narrowed it down and this is the anwser CAM POSITION SENSOR best 45-65 bucks spent depending on where you get it. Its the sensor plugged into the head that is right in front of where the stock divertor is i guess i bumped it and cracked it a little and this is what happened due to it.... The car is perfect now thats its replaced.
Justin
Pal215
18
Jun 11, 2017 09:47 PM
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
Black_EVO_MR
Oct 30, 2016 07:18 AM
neonglh
Sep 25, 2010 07:06 AM
05blue8
19
Aug 31, 2010 01:35 PM
