Is my Clutch Messed up? Or Tranny problems? HELP!
Old Dec 17, 2006 | 12:54 AM
Pure Playaer's Avatar
I have an ACT 6 puck Unsprung, ACT Pressureplate, and ACT Prolight flywheel
now i know that the act clutches, and 6 puck clutches make various noises, from squeeking n chatter n stuff.. but im gunna list a few things i hear from when i turn on the car, till i turn it off, tell me if anything seems weird please! ESPECIALLY DOWNSHIFTING AND 1st GEAR
[1] Startup - No noise, can hear clutch spinning like mini chatter
[2] Reverse - Sometimes Squeeks, and rarely makes a loud grind noise, liek somethings rubbing something
[3] 1st Gear - Now more than ever (Especially when slipping in traffic or on hills/driveways) it makes the LOUDDD SCREETCHHH noise that sounds like somethings grinding, and the clutch pedal shakes alot, it sounds terrible basically.. also it squeeks,
[4] Up Shifting - No problems
[5] Down Shifting to 3rd or 2nd - Rare in 3rd, but ALWAYS in Second (Starting tonight!?) it makes that same "rubbing" noise it does in 1st, but only when the clutch is ingaging.. and its very faint, and hard to hear, but if i keep pressing in, and depressing the clutch you can hear like scretch, not loud, but its very noticable.
Now Especially with [3] and [5] is that normal for a 6 puck clutch? or is it a little to loud, especially since [5] just started and [3] is just getting worse?
BTW clutch has only been installed for like maybe 1,000 miles, and only launched twice.
Could it be the install? Should I have it adjusted? (My tuner said not to do it because he's heard horror storys of adjusting it?)
Old Dec 17, 2006 | 01:11 AM
Bump! Someone Help!
Old Dec 17, 2006 | 01:19 AM
eh bump before i go to bed.. please let me wake up with some good news! or awsome advice.
Old Dec 17, 2006 | 01:25 AM
ttt 1 more time
Old Dec 17, 2006 | 09:58 AM
eh borming time bump
Old Dec 17, 2006 | 10:19 AM
ries's Avatar
not sure what to tell you bud w/ out actually being inside the car to hear the noises your talikng about.....
try adjusting the pedaly to the OEM specs and see if that helps out at all
Our cars are tricky and there are alot of problems w/ clutches due to installers mistakes
Just FYI unsprung discs are going to chatter during daily driving unless your constanly slipping the clutch at 5K to take off. They are designed specifically for race applications, this is why the manufacturer suggests the modified street disc for daily driving. Take it to a local dealer or your trustworthy mechanic and take them for a test drive and see if they can diagnos it w/ out ripping it apart.
Old Dec 17, 2006 | 10:58 AM
yea i understand.. imma try n take a good video today n show you all what its like..
but the chatter is like a LOUD kinda grind, and it also does it when downshifting to 2nd.. now i know 1st is normal, but what about downshifting?
am i hurting the clutch by taking off a 2k rpm every 1st gear?
Old Dec 17, 2006 | 11:39 AM
BUMP! ANYONE ELSE OUT THERE?
i need helpp lol
pweazee
Old Dec 17, 2006 | 01:18 PM
jrsimon27's Avatar
i think the chattering is normal a friend of mine has a twin cusco clutch and it does the same thing and as for the gears not feeling smooth you must adjust your clutch pedal a little higher then OEspecs this will make your tranny much smoother but just try that the clutch starts to engage at 3inches from the firewall
good luck
EVOLVEU's Avatar
Who is your tuner? You have a 6 puck, unsprung?? Its gonna chatter and squeel and make different noises. Its to be expected.
Old Dec 17, 2006 | 04:56 PM
yea but it does it when i downshift,
its not like normal chatter, im telling you.. especially since now its getting worse.
now starting today it does it when i downshift to 3rd gear, and second gear, right where its engaging.. i have video but i gotta get it on the comp need usb
Old Dec 17, 2006 | 05:35 PM
kapolani's Avatar
Dude...
Quit whining and take your car to a trusted mechanic.
How can you possibly expect someone on the internet to help fix your car for you?
If you need someone to hold your hand tell your mom to go with you to your favorite shop...
Old Dec 17, 2006 | 06:16 PM
mikiblueeyes's Avatar
I have Screethcing noises on my 2 disc RPS Carbon Clutch when lunching in1st gear. It goies away if I dont baby the clutch. LOL
Old Dec 17, 2006 | 06:56 PM
HOK's Avatar
HOK
Had an clutchmaster 6 puck... no sounds... take it in...
