Evo Ix Bov
Old Dec 20, 2006 | 12:36 PM
aZn tun3r's Avatar
Question Evo Ix Bov
alrite. this ones for all the veteran evo drivers out there. im looking for a bov for a EVO IX that has a stock engine wit few mods (eg. exhaust, intake, camshafts etc.), nothing over the top yet. I've heard a lot about the HKS SSQV bov and the problems it causes but can someone please explain what problems exactly. This would be greatly appreciated. I absolutely love the sound of the HKS but are there other BOVs that sound good as well?
Thanks!
Old Dec 20, 2006 | 12:38 PM
KOEvo's Avatar
Old Dec 20, 2006 | 12:41 PM
Smike's Avatar
Sure Ill explain. Search.
Do no put that BOV on you car. You do dont need a DV, your IX is fine, and works perfectly. The HKS is a push type - meaning it will not open at idle or when stopping and will cause engine stalling and generally make your car run crappy. Search VTA - read, read, read - and dont do it.
Old Dec 20, 2006 | 12:42 PM
boostinjuice's Avatar
ries's Avatar
you buying a bov is a waste of money IMHO, but if you must buy a bov for cool points or whatever get the Forge RS. the RS is a great stock replacement for 03-05 evos cuz they come w/ plastic POS bov's but the IX BOV is fine and works great
dont waste your money on worthless mods
Old Dec 20, 2006 | 12:46 PM
Smike's Avatar
Here, Ill even start you off:
https://www.evolutionm.net/forums/sh...highlight=SSQV
https://www.evolutionm.net/forums/sh...&highlight=VTA
Old Dec 20, 2006 | 12:56 PM
fitbikedominick's Avatar
If you want to get a bov im not going to flame you. I would recomend getting hard intercooler piping though. Then you gain some power and the bov won't need any adapters or anything, other than have to be recirculated. Or another route would be to get tuned and a mass air flow cone adapeter and cone filter, your car will sound way differnt and you will get to hear the turbo you paid for.
Old Dec 20, 2006 | 01:20 PM
robb86's Avatar
easter is fun.
nothing beats searching for chocolate eggs
Old Dec 21, 2006 | 03:00 PM
aZn tun3r's Avatar
thanks a lot guys
Old Dec 21, 2006 | 03:03 PM
-=SPECTRE=-'s Avatar
Thanks!
Tial 44mm VTA, definitely.
Old Dec 21, 2006 | 04:31 PM
GgreyEVOIX's Avatar
Like everyone said a bov is a waste since the stock one works fine up to a point(25 psi)
If you MUST have one then the 38mm Turbosmart dual port BOV is a pretty good valve. At least with this valve half the air recirculates back to keep your motor happy. But seriously keep the stocker!
Old Dec 21, 2006 | 05:25 PM
C6C6CH3vo's Avatar
My plastic valve holds 25 psi to redline fine and has sock drivability when under 10psi boost, of course I retrofitted a 10.5 psi pressure differential switch, 5 psi relief port, under diaghram ported, one 2 pos, 3 way solenoid, some tubing, fittings 3 months of R/D, also using the OEM charge spray relay and fuse.
03 - 05 Stock DV is not a POS - take one apart and see. It does leak like my grandma's butt however for it was designed to taper. But with rigging, holds great and drives great.
Old Dec 21, 2006 | 05:30 PM
Evo05lution's Avatar
you have the best d/v for your set up do NOT get rid of it! great thanks!
