fuel pump question
Old Dec 20, 2006 | 05:09 PM
whitersevo's Avatar
fuel pump question
so i was going to install a fuel pump, but I went and check underneath my seat, and It is making alot of noise, buzzing sounds, dont know how to describe it. but the question is, is this a walbro 255 already, or does the stock fuel pump not make noise.
Old Dec 20, 2006 | 05:11 PM
smokedmustang's Avatar
I never heard the stocker make a noise, but the Walbro definetly is loud with the back seat removed. I never took the seat out with the stocker in, as a matter of fact, so I don't know.
Old Dec 20, 2006 | 05:16 PM
kreionic's Avatar
Did you buy the car used? If not then its not a walbro
Old Dec 20, 2006 | 05:23 PM
whitersevo's Avatar
yeah fo sho, it is used, when I got it, it was using boost tube, to connect to the wastegate, and turbo nipple, to the boost solinoid.
Old Dec 20, 2006 | 05:33 PM
whitersevo's Avatar
bump, any body else got any info.
Old Dec 20, 2006 | 05:54 PM
whitersevo's Avatar
one more bump
Old Dec 20, 2006 | 05:58 PM
chaotichoax's Avatar
I'm going to guess it's a walbro... what did it should like while the car was not taken apart inside could you hear it at all?
I can hear mine most of the time
Old Dec 20, 2006 | 06:00 PM
whitersevo's Avatar
hmm not sure, i always had the radio on..
Old Dec 20, 2006 | 06:02 PM
sr20det91's Avatar
The most obvious solution is to pull it out and have a look. It will say walbro on it.
Old Dec 20, 2006 | 06:04 PM
whitersevo's Avatar
yeah I know but I am having problems taking it out, I couldnt get the lines off the barbs.
Old Dec 20, 2006 | 06:09 PM
ak47po's Avatar
Read this.
http://www.evomoto.com/tech_info.php...3_13&tech_id=9
Old Dec 20, 2006 | 06:12 PM
whitersevo's Avatar
Originally Posted by ak47po
Yeah I read that, still didnt help me, get the barbs off, I squeeze 2 things together and it wouldnt pull off.
Old Dec 20, 2006 | 06:26 PM
SASD209's Avatar
Admin Alumni
OK guys, listen......if you have nothing constructive to add, DON'T POST. I've cleaned this up, let's keep it on-topic.
J.D.
Old Dec 20, 2006 | 06:49 PM
halfnhalfevo's Avatar
Thanks for the link Ak47po... im about to install one within the week and it was a great writeup. and he was right about the clamp... its impossible by hands sometimes, a set needle-nose pliers will do the trick neatly. (worked for the vacuum lines to my DV)
