ACD equiped Clutch install
Old Dec 21, 2006 | 03:23 PM
daisaw1219's Avatar
Hi I need to know what else is involved in a ACD equipped car clutch install. The writeup in evomoto is for non ACD models. Ive heard that you must bleed the ACD system but i also heard there is ways around it. If anyone has any knowledge please let me know. Thank you.
Old Dec 21, 2006 | 03:28 PM
Steve@NoLimitmotors's Avatar
you gotta pinch the hose on the acd feed line because one of the lines has to come off to reach a bolt that bolts the t-case to the tranny, and once u get it installed, drive it on the lift to bleed the lines
Old Dec 21, 2006 | 03:40 PM
daisaw1219's Avatar
can you give me more details on the location of this hose and how do i bleed it.
Old Dec 21, 2006 | 03:49 PM
rraulston's Avatar
there is no need for this. Simply back out the bolt behind the line and walk the TC out at the same time. This adds 10 minutes to the job over a non-acd car. RRR
Old Dec 21, 2006 | 04:23 PM
n03lsevo's Avatar
You can also go to the dealer and have them bleed it for $120 or you can raise the car up on all 4, run the engine, shift to a few gears, and bleed the ACD line....if this is not true feel free to correct me.
Old Dec 21, 2006 | 09:16 PM
daisaw1219's Avatar
any more tips
Old Dec 22, 2006 | 03:21 PM
daisaw1219's Avatar
bump
Old Dec 23, 2006 | 09:38 AM
Ralph's Avatar
bump for an answer.
Old Dec 23, 2006 | 09:52 AM
esmjoe's Avatar
When your under the car you will see the acd line on the transfer case,looks like a brake hose, just loosen bolt and move line so you can get to bolt thats behind line ,as soon as you remove 17mm bolt reinstall line after you have removed the bolt , this way there is no need to bleed the system . Reverse prosise to install.If your fast enough you will not need to add fluid to acd container.
Little G
Jul 3, 2010 09:56 AM
Skywarp
Oct 24, 2007 04:03 PM
Jin4g63
19
Oct 28, 2005 08:09 AM
Mivo
Mar 24, 2005 06:44 AM
ivanko
Nov 25, 2004 02:53 PM
