upgrading to revolver cams???
Old Dec 28, 2006 | 05:48 AM
SwiftEVO's Avatar
Originally Posted by steelcityevo8
why cant u run them in the stock head? do u mean port work or springs retainers. i know u need to upgrade the springs and retainers as they come with!!
Sorry I just meant the springs and retainers.
--Josh
Old Dec 28, 2006 | 06:38 AM
ForcedFedRS's Avatar
I've seen these cams run on a vehicle with no head work done, and there were not any issues. Car was controlled with Autronic and the idle was lumpy, but not unbearable, the car pulled like mad for a stock turbo. There cams are going in my car, they are worth the extra cash IMO.
Old Dec 28, 2006 | 08:34 AM
ez's Avatar
ez
I did a ton of research when I was shopping, and came to the Revolver conclusion...very happy with the choice. I think you may eventually come to the same.
However, since then some new cams have come on the market with similar specs that could be considered. The thread I posted above has some good information on the HKS vs. Revolver.
BTW - I hope to replace my TME with a 50 trim this year...can't wait
Originally Posted by Randy
Well Im out in the market for a new set of cams, tired of HKS 272's and want to buy something that improves spoolup and add more power/torque to my 50trim setup.
I will keep checking this thread
Old Dec 28, 2006 | 08:52 AM
Randy's Avatar
ez:
Did you have other brand of cams before or you went straight to the Revolvers? I might buy them as a New Years gift for myself I'll have to contact Buschur for them I think. Do they come in different setups like the HKS or they are only one type of spec?
Old Dec 28, 2006 | 09:51 AM
dryad001's Avatar
Are they available yet?
Old Dec 28, 2006 | 11:11 AM
Randy's Avatar
Well for what I've been reading in the past 2 hours (Im home sick with horrid flu and fever) the Revolvers are agressive as hell, they need to be degreed for proper idle quality (still you will have a lumpy V8 type idle, which I dont mind ) you will achieve beter turbo spoolup ( I wonder how better) and improved torque and also top end will be much better, they or so people say are compared to HKS 272's but I think for what I have searched, JUN's are less agressive.
Someone with experience in both cams should really chime in and give us some proper knowledge based on real facts.
Old Dec 28, 2006 | 03:05 PM
steelcityevo8's Avatar
thanks for some opinions guys, please keep chiming in
Old Dec 28, 2006 | 10:16 PM
ez's Avatar
ez
Nope. Coming from stock cams. They only list one set for 4G63T.
I hear that there are several companies including Cosworth, Tomei, and JUN that are doing higher lift designs now as well...but I have not researched them.
Yes, the idle is aggressive, but not near as aggressive as most of the V8s I've owned and worked on for a living. These cams are not very aggressive in the grand scheme of motorsport. With the right tuning, these can find a stable idle even with the factory ECU/MAS setup. But stable does not necessarily equal smooth. Hot rods and race cars don't usually have a "smooth" idle...so if you are not into that, I would not recommend these cams.
ez:
Old Dec 28, 2006 | 10:26 PM
ez's Avatar
ez
Like I said, mine run very well set to 0/0. The HKS 272/Revolver A/B test with dyno sheet is in the thread I posted.
Now all you need is to find some numbers from a like setup using JUN, Tomei, Cosworth or other cams...and draw some basic conclusions. Remember I have a ton of flow work done in the head/manifolds
Old Dec 29, 2006 | 12:37 AM
brokenRS's Avatar
what cams would give you most power and torque for stock turbo set up?
Old Dec 29, 2006 | 08:19 AM
ez's Avatar
ez
That one will take a lot of research. To my knowledge, no one has done an A/B/C/D/E...etc. for all major makers test in the manner that Timzcat did with Revolver and HKS. My feeling is that no one probably ever will.
Old Dec 29, 2006 | 11:12 PM
Randy's Avatar
Hmm still wondering what this babies will do for my 50trim, still pondering between these and the Jun 264's
Old Jan 31, 2007 | 10:30 PM
BlownIncome's Avatar
I have heard his car in person, IMO it sounds pretty freakin bad azz. Currently I'm trying to decide between a set of these cams or a set of Tomei 280's........whelp, that's my 0.02
Old Jan 31, 2007 | 11:42 PM
Recks's Avatar
LoL would be nice if they came for the evo9 as well..
Old Feb 1, 2007 | 04:14 AM
WhtEvo05's Avatar
Make your life easy. Call Buschur.
I just saw a thread somewhere about the fact that he is not recomending Revolvers anymore or the customer service is bad.... can't remember.
Give him a call since he sold and installed quite a few of them. I'm sure he can answer all of your questions.
I'm runnin Jun 272's.
Good luck
