Weirdest Problem Ever Eoncountered...
If you can hear and feel it but have no leaks in your plumbing there isnt much else that it can be. Something must be blocking the intake tract.
You should:
1. check engine lights?
2. check boost with different boost gauge
3. check for boost leaks
if ok then...
1. change the plugs.
2. check the coil packs for defects
3. check the spark plug wires
4. check for leaks around the MAS
if nothing still...
1. check for fuel leaks
2. check for injector electrical harness for looseness
3. check injectors
if nothing still.......
take it somewhere because you've missed something...
bryan
if ok then...
if nothing still...
3. check injectors
bryan
I agree with him. I've known 2 people to have this problem. I'll bet the hood was up on the dyno and that's why it made power. Close proximity of the duct and hood when closed is most likely causing a huge amount of "suction" and is fascilitating the problem. When the hood was open on the dyno there was nothing to restrict it.
For future reference, here's my calling card:
Bat-talon
My crew of saved Gotham City Residents:
someone help please
Boost Leak Sound
3rd gear..6k..no boost..loud vaccum noise
Weird boost problem, please help
boost control problems
Huge problem, please help!
help loud whisle
Help on boost loss issue
Boost Leak... Maybe?
Strange sound, loss of boost, BOV or wastegate?
PS. I spent a week of constant troubleshooting trying to figure this out about 2 years ago...
came home from dinner, read the thread, removed snorkel (which had no screws holding it down), drove car which ran and drove perfect, kicked myself in A*S, then posted this...
OMG, i cant believe how stupid this was, i mean i knew it would be dumb but not this dumb. I feel so dumb, lol. Its funny to cuz it would have taken me a week to figure it out too. I did a spring and o2 housing install the night before last and one of the little screws holding down the snorkel scoop thing dissapeared so i took the one off my car for his car. And i had already been missing one because i lost one of mine too when I did my MBC install. I cant believe it was that stupid, thank you for pointing that out to me!!!
Yeah, when I figured it out, I didn't care how stupid it was, because being able to fix a huge problem like that within seconds with no parts needed was a huge relief.
As a suggestion, instead of removing the snorkel, go grab two clips out of your trunk lining and use those. The trunk lining has 10, I think, so it won't matter if you remove 2 of them.
how did you actually figure out it was that? I think i would have just installed an intake eventually, but how did you figure it out?
