Gearbox removal.
Gearbox removal.
I helped a couple friends replace a clutch on an 8 the other day. It was agreed the worst part of the removal was trying to get the release bearing to let go. Otherwise it wasn't as bad a job as I had envisioned. We removed the transfer case from the gearbox and were able to remove the (VERY HEAVY) gearbox with only a slight clearence issue.
Has anybody actually broken their GB because they didn't know about the release bearing?
I assume the reasoning behind its fastening is so it doesnt develop wear as fast on the collar?
i couldnt get the throw out bearing to let go either so i went through the clutch fork hole and took the pressure plate bolts out of the flywheel and then slid the transmission off. i was a huge pain, but i didnt break anything
that's exactly what we had to do. Couldn't get the TOB to release. It sucked ***.
Its fairly easy and simple if you know what your doing.....pull on the fork then stick a long flathead between the collar and the tob and seperate them by rotating the screwdriver
its a pita but it sure beats breaking things
Seriously...the TOB isn't all that bad. A little research prior to doing a job eliminates alot of silly BS.
