problem help please!!!
Old Dec 31, 2006 | 02:22 PM
evoteddy111's Avatar
Hey guys im having problems with my IX, it seems that my car has a fuel cut around 4,000rpm's....Some people say its from to much boost or waist gate....im pussing only 20psi so i know thats not the problem or is it??if u could please help me out i would really appreciate it!!! oh and it started to do it after i put the turbo timer in!!!
Old Dec 31, 2006 | 02:25 PM
Ultimate CC's Avatar
what mods do you have...
Old Dec 31, 2006 | 02:30 PM
intake
full exhuast
xs boost controller
blitz type 0 tt
02 housing
& manifold
Old Dec 31, 2006 | 02:31 PM
Assassin's Avatar
Does this only happen at WOT?
Old Dec 31, 2006 | 02:35 PM
bvdawg13's Avatar
do you have a flash or anything? i had about the same mods as you plus cams and it happened to me, you need a flash
Old Dec 31, 2006 | 02:39 PM
ok thanks i figured that, i just wont drive it hard untill i get tuned for the AEM on the 13th...Thanks guys
Old Dec 31, 2006 | 02:40 PM
ModifiedMR's Avatar
Don't know if you actually need it with those mods, but before the tune you should get a walbro 255 fuel pump. Especially if you plan to keep moding because your just gonna need it anyways.
Old Dec 31, 2006 | 02:41 PM
im sorry but WOT???if u mean what gear, mainly 3rd
Old Dec 31, 2006 | 02:44 PM
1BlackEvo9's Avatar
"Wide Open Throttle"
Old Dec 31, 2006 | 02:45 PM
yea i just wanted the basics for not being on tune..but when the time comes for tune day, its going to be fun.. Ill deff post some #'s/graph's Thanks again guys
Old Dec 31, 2006 | 02:46 PM
oh u bet
Old Dec 31, 2006 | 02:47 PM
1BlackEvo9's Avatar
oh u bet
You know it
Old Dec 31, 2006 | 03:35 PM
last ? can this damage the motor??and is it a fuel cut?
Old Dec 31, 2006 | 03:50 PM
thedarkside's Avatar
Well if you are pushing your car at WOT without a tune then yes you can easily blow your car up. Especially since you are not running a fuel pump. The reason you are cutting at WOT is because your knock sensor is pinging through the roof and the car is cutting to tell you that you will blow up if you rev any higher. BABY IT UNTIL YOU TUNE!
