Low whp ?
Old Jan 3, 2007 | 09:13 AM
Epidemic's Avatar
Low whp ?
[IMG][/IMG]
I made 279 hp and 285 tq at buschurs with a custom tune w/ecuflash mods are 680cc injectors, walbro 255, clipped turbo,21psi, 93 octane ,2.3 stroker, intercooler and lower ic piping, TBE w/test pipe, 264 cams from hks, and ats clutch. I always thought my dyno numbers were low. My afr max was 11.5. What do yall think about my numbers? And buschurs dyno is a mustangdyno. I think my numbers are really low and my car doesnt feel any faster when they did the cams stroker and the tune. Spent a lot of money and felt no gains. Only difference I feel is the car runs smoother and boost is a little sooner but where is the extra power? How should I approach this? I did a boost leak test and it holds at 21 psi fine. Do I just have a weak evo? Im ready for a turbo upgrade and hope I dont make ****ty power with a bigger turbo.
Old Jan 3, 2007 | 04:33 PM
Epidemic's Avatar
no responses did i post in the wrong section?
Old Jan 7, 2007 | 10:37 PM
Epidemic's Avatar
few days later bump
Old Jan 9, 2007 | 09:45 PM
Evo_SpeedKing's Avatar
what are you compression #s?
what did Buschur have to say about your low #s?
Old Jan 9, 2007 | 10:07 PM
MRevolutionRed's Avatar
that does seem really low
Old Jan 10, 2007 | 12:18 AM
JohnBradley's Avatar
Do you have the ability to log a couple pulls? If you do look for things like: unstable AFR's, knock, IDC, etc. On the hardware side do a compression check, check the cam gear settings, make sure everything is tip top. Sometimes it can be really dumb stuff that causes issues.
Old Jan 10, 2007 | 12:03 PM
BerserkerX's Avatar
those numbers seem really low especially for 93 on a mustang dyno i did a road dyno and all i have done is a Buschur TBE and an AEM intake. As for tuning issues there is a few things i found online like cam tunes and a different restrictor pill leading to the waste gate and i got around 252WHP and 260WT on 91. As JB said check for knock and compression checks.
Old Jan 10, 2007 | 12:15 PM
boostingevo8's Avatar
I made 284 whp 290 wtq on a mustand dyno too.......
My compression is 140 across...
My friend check the comprssion on his newly built 4g63 ( pistons & rods) and his was only 160 across with no miles on the motor..same compression guage.
I ran a 12.68 at 108mph.......I thought my WHP #'s were kinda low too, but on a dynojet I am over 300 whp and you are right near 300 whp.
My cams aren't the greatest....works 269. Are you on stock turbo? I'd do a compression check and then go from there......
Old Jan 12, 2007 | 12:02 AM
Epidemic's Avatar
Compression is 165 on all 4 cyl. My stock turbo just recently took a dump (oil seal). Yes this was stock turbo stock hotside however it was clipped. I am now going with a GT3071, I have no data loging capabilitys other than an aem uego and the a/f looks great. The boost never held well always went from 21 to 18 sometimes even lower. Anyone have any Ideas?
Anyone think I shouldnt be concerned? I was also thinking maybe the oil seal going bad might have had something to do with the low power and boost leak. Again I didnt hear any leaks with a boost leak test. The stock turbo was taken off today with the help of a fellow evo member. I hope I wont be stuck with unusally low hp with the new turbo.
