Drive Belt Replacement
Old Jan 4, 2007 | 11:17 AM
donour's Avatar
There's a discrepancy in the service schedule given in the owners manual. It states that the main drive belt should be replaced every 30k miles. The mitsubishi shop manual only stipulates a belt check (tension and resonate frequency check) at this interval -- even under the severe maintenance schedule.
Of course even the check requires special tools, a tension meter and a MUTIII.
Which do experienced engine builders think is the better action at 30k miles? It seems pretty early to be replacing that belt. On the other hand it's only like $50 from mitsubishiparts.com.
d
Old Jan 6, 2007 | 08:20 PM
silverofs's Avatar
this is an advanced question??? just look @ the belt if it's hard or has cracks developing or there are cracks replace it.....
Old Jan 6, 2007 | 08:30 PM
dubbleugly01's Avatar
replaced mine at 30 k and then again at 60k. It's cheap enough and easy enough for the piece of mind.
