Buschur Evol 9 LICP installed
Old Jan 6, 2007 | 10:07 AM
Mitsu3's Avatar
Just installed the evo 9 specific licp on my mr. The stock licp was a pain in the *** to take off becasue the bolts are hard to reach. I did not take off the bumper just the undertray.
The car feels more responsive under 5000rpm. It definetky feels faster under 5000 but it feels the same above 5000. Also i noticed my rpms do not drop as fast when i push in the clutch to shift, which is kind of better. I am happy with this peice and if you get it make sure you clean inside it very good b/c mine was dirty.
Old Jan 6, 2007 | 10:11 AM
fromWRXtoEVO's Avatar
Good review. I wrote a review for the same LICP when they were first launched. The pipe was great but I also found a lot of dirt inside of the pipe as well.
This is my review:
https://www.evolutionm.net/forums/sh...d.php?t=212558
Carlos
Old Jan 6, 2007 | 10:14 AM
Mitsu3's Avatar
yea it made the turbo a little louder and the pipe fit perfectly.
Old Jan 6, 2007 | 11:07 AM
vmsturbo's Avatar
This is definately good to hear, i've had all my parts sitting in my garage waiting for a day to install it all.
Old Jan 6, 2007 | 04:09 PM
brp's Avatar
brp
my girlfriend bought me the same LICP as one of my x-mas presents, just installed it a couple days ago but i have not been able to really drive the car yet because it wont stop snowing in this place! great fit...
Old Jan 6, 2007 | 11:05 PM
BlueDemon's Avatar
I've a buschur intake kit with a semi-dirty suction pipe. How did you clean yours cuz my hands are too big to fit all the way in and the dirt inside the pipe is kinda hard to remove, almost stuck to the pipe!
Old Jan 6, 2007 | 11:30 PM
spyderx's Avatar
Is it much heavier than stock?
and how does it hang w/o the hanging bracket?
Old Jan 7, 2007 | 07:51 AM
David Buschur's Avatar
I'd guess the weight of our pipe is as light, maybe lighter than the stock pipe with the large rubber couplings it uses.
The dirt in the tubing. This should never happen as they are suppose to be inspected by atleast 2 guys before they leave. The pipes are cleaned with a water based solvent and have a long flexible brush run through them and then rinsed out with HOT water.
Glad the fitment is excellent and the power is improved. Sorry about the dirt.
Old Jan 7, 2007 | 09:56 AM
EVIL_EV0's Avatar
I highly doubt any LICP or turbo exit pipe is going to make much of a difference on a stock turbo'd car. Some of them sure are pretty though.
I would love to see a before and after same day same car dyno that shows any kind of gain. You might be a little quicker in the 1/4 mile due to less weight..... in your wallet.
Old Jan 7, 2007 | 10:11 AM
jrsimon27's Avatar
when i installed mine what i felt was it pull harder above 6000rpms
Old Jan 7, 2007 | 10:58 AM
brp's Avatar
brp
mine seemed a touch heavier than the stocker, but it also felt like a thicker/stronger material. it took me a few minutes to get it to sit just right so that it wouldn't be sticking too low, but once i got it right its a perfect fit, i can have the undertray on there and it doesn't even touch it. now, i just wish the weather would help me out a bit so that i can take the car out for a drive
also mine was pretty clean!
Old Jan 7, 2007 | 08:14 PM
Recks's Avatar
Spools any quicker?
Old Jan 8, 2007 | 07:53 AM
You know all of these parts if designed correctly generally just keep adding to the performance of the car. Doubting that it will work on a stock turbo'd car isn't a reasonable assumption. Hear me out......look at the fastest stock turbo'd EVO's/DSM's. They have the most stuff done to them. It's not like you are going to put a turboback and an airfitler on your EVO, dump in a tank of C16, turn the boost up to 40 psi and run 10.50's. It takes a combination of the right parts all working together, each one adds to the next.
Things like this do make a difference.
Old Jan 8, 2007 | 01:01 PM
dafunk630's Avatar
all i know i installed my nisei licp and helped out a lot the spool!!
raph
23
Aug 22, 2011 12:06 PM
Q@EvoPowerMods
Feb 17, 2009 10:14 AM
EVO+IX+MR+SE
29
May 25, 2007 09:38 AM
eponti
10
Nov 7, 2006 11:40 AM
alan678
Aug 28, 2006 07:33 PM
