Various Intercooler Weights
Old Jan 25, 2007 | 07:41 AM
jmartinez1170's Avatar
But you do agree you need the right ic to fit your hp needs thats what im trying to get at.
So weight saveings in this dept really dont happen.
Old Feb 11, 2007 | 01:44 PM
94AWDcoupe's Avatar
slowboy 20.5
e-bay AMS copy 21.5
Old Feb 11, 2007 | 03:26 PM
EVOlutionary's Avatar
Thanks, List updated!
Anyone know the weight of the Blitz intercooler?
Old Mar 15, 2007 | 06:21 AM
MR 600's Avatar
I just got my Perrin IC and it weights in at 22.7 lbs.
Also, i spoke to the guys at Nisei, and they said that their new Comp intercooler is about 2-3 lbs heavier then their normal street intercooler that they first came out with. So, you might want to add the Nisei comp at about 29 lbs
Old Mar 15, 2007 | 07:51 AM
94AWDcoupe's Avatar
pwr = 23lbs
e-bay 24x12x4 = 22lbs
xs engineering GTR tube and fin = 16lbs (newer models may be extruded tube)
Old Mar 15, 2007 | 10:13 AM
honda-guy's Avatar
what about FullRace tube and fin IC.
Old Mar 15, 2007 | 10:34 AM
94AWDcoupe's Avatar
Full race and injen use this IC. It is a PWR core with evo specific endtanks. Not sure I like the design. The angle of the inlet is too extreme. Very hard u turn to get to the bottom 1/4 of cooler. Should weigh the same 23lbs of the PWR.
Old Mar 15, 2007 | 11:54 AM
List Updated. Thanks!
Old Apr 20, 2007 | 07:56 PM
SWOLN's Avatar
Originally Posted by EVOlutionary
Autocross -- handling is #1. NOT adding 10-15 pounds to the very front of your car may be more beneficial than the 10whp you would gain. Don't need to worry too much about heat soak on a 30-60 second run of varying on/off throttle.
EVOlutionary
Is this the reason you have the ARC now? ...and Oh yeah, bump for update on weights.
Old Apr 20, 2007 | 11:10 PM
RazorLab's Avatar
ETS - 20.8 lbs
Old Apr 22, 2007 | 06:36 PM
Actually you can slap me and call me a ricer I got the ARC #1 for looks. #2 reason was weight. It was the lightest one I could find that would exactly match the opening on the Voltex front end I am running. The stock one just looked completely stupid with that front end.
I have not weighed the ARC unit yet, but I will before the car is put together . . .
LIST UPDATED!
EVOlutionary
Old Jul 19, 2007 | 12:59 PM
kduncan01's Avatar
What size core is the ARC and the PWR????
EVOlutionary how much did you pay for the ARC??
Old Jul 19, 2007 | 01:03 PM
KevinD's Avatar
weird. i weighed my buschur race core, it was 27lb 8 oz. the stock one on the same scale was 9lb 7 oz. that is without the couplers.
Old Jul 19, 2007 | 03:28 PM
Don't really know the size of the ARC. It is a little thicker than stock, about the same height, but about 6" wider. This is the "073W" model which designates it has fewer, thicker tubes and is wider than stock. I got it for $1000 used.
Old Jul 20, 2007 | 03:53 AM
EVO8LTW's Avatar
stock--10 lbs.
Buschur Deluxe --20 lbs.
Full-Race (same as PWR and Injen)--20 lbs.
I've wondered the same thing, but I just got a good deal on a FR FMIC and decided to give it a try. Going to install it this weekend.
I thought the FR/PWR unit was worth a try to see if it would aid spool-up (good for autocross) as well as power, due to less pressure loss than stock and, I hope, less pressure loss than the typical bar/plate units. There is also the issue of a tube/fin allowing air through to the radiator better than a super thick bar/plate unit (like the Buschur Race), and coolant temps do play a huge role in power on a stock ECU car in repeated WOT runs since the stock ECU dumps in fuel when the temps are elevated even from a single one gear pull.
