stock headstuds - high boost
Old Jan 11, 2007 | 02:59 PM
evolife04's Avatar
nvm
Old Jan 11, 2007 | 03:05 PM
riceball777's Avatar
arp head studs wont hurt unless you install them wrong and do someting stupid like install them 1 by 1 with out taking the head off and replacing the headgasket
Old Jan 11, 2007 | 07:35 PM
BerserkerX's Avatar
23 pounds and not very long on pump but i wish we had 93 where i am though stupid 91
Old Jan 11, 2007 | 07:44 PM
ihatepotholes's Avatar
stock headstuds running 23-24psi on straight 93pump for quite a while... no problems at all
Old Jan 11, 2007 | 07:50 PM
34Turbo's Avatar
Stock head studs @ 25psi and pump for about 18K miles. No problems. Now I got head studs since alky is on the way. Planning on running ~30psi.
Old Jan 11, 2007 | 09:39 PM
-=SPECTRE=-'s Avatar
Which is exactly what a lot of people and shops do.
Old Jan 11, 2007 | 09:46 PM
precisi0n's Avatar
This weekend I'm pulling the head to replace a leaking head gasket because the stock headbolts s-t-r-e-c-h-e-d. While I'm in there, I'm putting ARP headstuds, 280's, and dual valve springs Ran 30psi for a year, now there is a problem. Lasted longer than I thought they would Hope this helps
Old Jan 11, 2007 | 09:49 PM
might as well get a new head
Old Jan 11, 2007 | 09:50 PM
precisi0n's Avatar
the head I want is $3 g's +++... Not a chance
Old Jan 11, 2007 | 09:55 PM
triple6's Avatar
please explain.
Old Jan 11, 2007 | 10:33 PM
GregGSC's Avatar
Originally Posted by Ultimate CC
arp replacement was a fad that is now being seen that they are really not needed, look at all the 9s...
Dont forget to mention the 9 has an extra gasket layer than the 8 so it is thicker head gasket.... dont know if its better persay but i would lean that way. but i still agree with you.
honastly i say the stock head bolts are fine on the stock turbo. I dont really like the ARP head studs. why very simple.... Tim at AMS did the right thing when he put together the AMS/TMS head stud kit(yeah its more expensive but well worth it). The washers are actually larger than the ARP grabing more area of the head. they are also a H11 material which is quite a bit stronger than the $100 arps most people buy.
I say if your going high 28+ on the stock turbo and alky or a larger turbo go to the AMS head studs over the ARP units.
We run them on our 9.3 comp time attack motor at 25psi with out any problems yet!
Old Jan 12, 2007 | 12:24 AM
94AWDcoupe's Avatar
In dsm world the stock 6bolt(thicker than 7bolt) studs have been pushed with 40psi on a gt42r 740whp. I am currently swapping to a 7 bolt block in my gt35r car. I will be running stock studs at 35psi.
99% that blow a gasket would blame it on head studs stretching.
99% of the time it would be detonation.
cylinder pressure for a the majority is in the 2000-2500psi range.
properly tuned this peak pressure will occur at 14-16 degress after top dead center. the piston is in a nice position to turn the crank.
improper tune results in 4000 psi at or near TDC. the explosion is instantaneous and the piston is straight up and cant rotate the crank. something has to give. the head lifts.
Old Jan 12, 2007 | 12:50 AM
agolgan's Avatar
27 on pump plus meth for over a year. Turbotrix tune with no problems.
Old Jan 12, 2007 | 06:39 AM
Gusl's Avatar
Head studs
28 pounds on 93 oump & alky. Gt 37R turbo stock head, stock studs so far no worries. When it goes it goes. Till that day im on the gas every chance I get.
Old Feb 12, 2007 | 11:04 AM
DJ Brett B's Avatar
question
those of you who are running 28 PSI + on stock head bolts, how long have you been running that setup? Also, do you roadrace or Auto X?
