Service engine soon..HELP
I just installed a Turboback exhaust and this light came on after I hopped on the car. Is it because I dont have a cat now and the o2 sensor?? Is there any fix or should I just not care until emissions comes and I change to my stock exhaust and unplug the battery to reset it?? HELP...thanx
just follow this link..
https://www.evolutionm.net/forums/sh...d.php?t=208195
most likely it is the o2 sensor.
but what is the code number?
if you goto goto autozone or pep boys, they can pull the CEL code for you for a couple dollars. then you will know what you are dealing with, and how to go about fixing it.
Come on man this is like the most discussed thing on here.
If you would have spent maybe 5 min searching you would have found it very quickly.
In the how-to section there is atleast 2 threads on how to fix this problem.
Go search, print your results, jack up your car and fix the problem.
End of story.
Ktorres0327
20
Oct 2, 2014 02:26 PM
