help with misfire~~~!!!
Old Jan 11, 2007 | 04:04 PM
whitersevo's Avatar
Hey guys, decided it was time to change my spark plugs, i put in the NGK BPR7ES plugs, gapped them at .026.. Heres the thing I can here is miss when I rev up the car.. no miss fire codes at all.. any suggestions? thnxs
Old Jan 11, 2007 | 04:06 PM
Cirrusly Evolvd's Avatar
Check your injector connections. Missfires can be cause by many other factors than just plugs.
Old Jan 11, 2007 | 04:09 PM
whitersevo's Avatar
hmm yes this is true, but the car was tuned not to long ago, no problem showed up?
Old Jan 11, 2007 | 04:21 PM
whitersevo's Avatar
bump
Old Jan 11, 2007 | 04:30 PM
WickedWhtMR's Avatar
check your injector connections, check the plugs. Did you change anything else? This happened to me after i installed a bunch of stuff. Took it to the shop. Shop owner puts it on the dyno after i drove it there gently. Car screamed to 8,500 rpm no missfire.
Old Jan 11, 2007 | 04:35 PM
whitersevo's Avatar
check the injectors they are tight on there.. didnt change anything else.. tuned the car bout 4 weeks ago. i dont see anything wrong wtih the plugs.. not cel. just cant figure it out..
dookgvr4
Aug 22, 2016 04:56 PM
thiagobr03
14
Nov 13, 2011 09:05 AM
Xearo
Aug 25, 2009 11:53 AM
Evo9"Miss Rose"
30
May 17, 2008 08:47 PM
pls1968
Oct 31, 2007 07:06 PM
