drivetrain damage..
here is my take if you do a dump with your foot still on the clutch pedal not side step it and have sufficient air pressure in the tires to get wheelspin then you wont hurt nothing braking the tires loose saves the drivetrain,whats happening to you guys is that you lower the tire presurre then your standing on a track with vht material where do you think all the energy will go if you dont get wheelspin? it will go back to the transfer an boom it wil go!!!!!
yes getting wheelsipn wont give you your best time in the 1/4mile but at least you will save the drivetrain if you dont like this method then you need to learn to slip the clutch but the stock clutch wont last nothing and also dont try dumping and aftermarket clutch or a car that doesnt have a ristrictor pill cause it will also damge it!
dahuii77
20
May 20, 2010 01:21 PM
