Check out my Dyno results
I hope this is in the right place, but here goes.
My mods are:
ECUTEK, Perrin 3" DP, Perrin Cat Delete, Agency Power Cat Back, Agency Power MBC, and AEM Intake. Tuned at Vivid Racing.
From what I've read it seems like these mods would be making more power. The tuner said that the blow off valve is leaking/not holding boost, thus the wavy boost curve. I was just wondering how much a leaky stock BOV would effect the overall power.
The last few runs I did see it pull around 275-278hp, unfortantly I left there totally forgetting to get any dynosheets. It took almost a month to get them to finnally email this one, which isnt even one that has the full HP on it.
Either way, I just wanted to get some more info on this wavy boost curve, and find out for sure if its the BOV, the tune or what. Thanks for looking.
My mods are:
Seems like good dyno numbers on a mustang dyno with your mods. Also I replaced my stock plastive BOV the other day with a EVO 9 metal one and I picked up two pounds of boost. So mine was defitanly leaking.
It depends on the dyno but a typical correction ratio on that dyno would be about 1.15 so 278x1.15=320 on a dynojet which is strong since you do not have cams....you should be happy.
nice #s for a mustang dyno , with later mods just keep going back to the same dyno this way you know the real difference your new mods made, my dyno sheet was similer. wavey hp , tqu and boost curves , you running the stock turbo?
Well at first he thought it just needed a MBC, which did straigten out the wavy boost, but only a little bit. He also thought that maybe the waste gate was leaking, but since he nor I have ever really heard of the waste gates being bad on an evo, we just figured it was the BOV. And yes that is the stock turbo, everything is mostly stock except for the mod that I listed. I guess I didnt realize how much lower the mustange dyno read. Thanks for everyones input so far btw.
Not all Mustang Dynos read the same, and all previous dynosheets from Vivid have read like a Dynojet. It's highly unlikely this car is putting down 320whp on a Dynojet on 91oct. The high 270s are probably accurate for this car on a Dynojet, which means it's a little underpowered, but 91oct sucks.
well soon i am going to get a new bov, probly the mr metal one and see if that fixes it with another tune. I just hope there is nothing wrong with turbo or somthing serious. Seems like no one else has this problem.
Brett
