i broke my evo!!
Old Jan 13, 2007 | 05:37 PM
  #31
Cirrusly Evolvd's Avatar
Snapping the axle on our cars is actually common. I snapped my left rear in exactly the same circumstances you did. I had to purchase a used rear diff and a new axle. (Splines are still stuck in my old rear diff)
I have an 03 and I drove the car home at 20mph without any difficulty. I don't know what kind of shenanigans the ECU would pull since you have an ACD.
My instinct would say that you need to replace your driveshaft and diff if needed. Go to www.driveshaftshop.com if you want to buy some beefier axles. I'm going to be doing the same soon.
Old Jan 13, 2007 | 05:40 PM
  #32
bigric09's Avatar
didnt his post sound amazingly similar ? lol
Old Jan 13, 2007 | 10:46 PM
  #33
4WS Tuning's Avatar
Originally Posted by thatguy
That could happen with a single disc BUT you have a hell of a higher chance with the twin disc to break driveline parts on a sticky track if too much stress is put on the drivetrain.
I'm not knocking the clutch, im thinking about buying it and putting it into my ix.
it did happen with a single disc lol... its not " that could happen" he has the 4 puck single disc....
i didnt realize that was possibly, i figured at his power level it would slip...
Old Jan 14, 2007 | 01:14 AM
  #34
DrSmile's Avatar
You can usually just service the diff and knock out the splined part, although typically it twists the splined section enough to have to pick out little pieces... Have you tried taking apart your old diff? It would be nice to have as a spare.
Old Jan 14, 2007 | 03:29 AM
  #35
BerserkerX's Avatar
I have not had any problems with any parts like the axle or the diff before but i dont launch near as high as most do either
Old Jan 14, 2007 | 04:27 AM
  #36
KawRider's Avatar
Originally Posted by Tim893
i dont think you should launch ur evo at 6700rpm....
+1 billion.
THat is way too high to launch without braking something.
Old Jan 14, 2007 | 05:17 AM
  #37
civicevo380's Avatar
This is why I'm not planing on going to the 1/4 mile track, only circuit racing. The 1320 is too much stress on an AWD car drivetrain.
Old Jan 14, 2007 | 07:42 AM
  #38
I'm working on that. I used a breaker bar and a very large hammer and the splines won't budge. I have the diff out of the case and will look into having it drilled out.
Old Jan 14, 2007 | 12:21 PM
  #39
thatguy's Avatar
whooops, i thought he had a twin disc,
I thought the cluch would have just slipped, I guess I need to wakeup.
Old Jan 14, 2007 | 12:40 PM
  #40
evilempire76's Avatar
Man, that sucks! I hope you get everything back together.
Old Jan 14, 2007 | 12:53 PM
  #41
purevibez's Avatar
good luck with that ive broken a few drivelines in my eclipes but thank god i havent ripped the hell out of the evo.sounds like u really hurt something in the front too though.
  #42
Evoryder's Avatar
6700rpm launch... interesting
Old Jan 14, 2007 | 02:20 PM
  #43
dxbevo9's Avatar
<---- scared as FiUck coz he launches his car on a daily basis
gr8stevo
Nov 30, 2015 11:18 AM
Slobaru07
Dec 4, 2011 05:37 PM
JohnEB
Nov 22, 2010 09:45 AM
diiirk@AwdMotorsports
Apr 2, 2010 10:56 AM
Casper.
Jan 25, 2009 07:24 AM
