bov ???'s
Old Jan 14, 2007 | 11:41 AM
dmit's Avatar
bov ???'s
hey guys, im abou tto get the hks evc 6 boost controller and i was wondering how high i can go on my stock bov, of if it would be more benifical to upgade that thing, (currently hks carbon ti turbo back, megan bp & 02 housing, ultimate racing test pipe, autometer z gauges (not installed qutie yet) and aem short ram intake,) im sure this question has been answered on this but im semi new and i would gretly appriciate it if i could just get and answer, becvause you guys relly seem to know what you doing!! thnks!!!!
Old Jan 14, 2007 | 11:45 AM
boostinjuice's Avatar
it cant hold worth ****... get a IX bov.. it holds 23-24psi... the stock POS you have only holds 19psi.. if your lucky
Old Jan 14, 2007 | 11:48 AM
scottatyamaha's Avatar
The only BOV i would get on stock turbo, would be the stock BOV that comes on the new EVO 9. It is metal and can hold 25psi.
Old Jan 14, 2007 | 11:50 AM
Waz996's Avatar
ditch the bov,
first you dont need it coz u wont be boosting more than 21psi with your mods,
second the stock bov is recogned to be super efficient
third it wont do you any power gain
fourth it might do more harm, since ur ecu needs the psh psh air that it'll blow out in the air for nothing..
how about u get an mbc instead AND a flash to top it all up..
Wael
Old Jan 14, 2007 | 12:15 PM
Waz996 is right though...you do not even need a BOV yet. Get the basic first. But if you want a BOV get the EVO 9 one.
Old Jan 14, 2007 | 02:50 PM
dxbevo9's Avatar
EVO IX bov is the way to go!
Old Jan 14, 2007 | 03:07 PM
Warrtalon's Avatar
Waz is a little confused. He thinks the guy is only talking about VTA, but he's not. Waz also thinks all stock BOVs are good, but they're not - the one on this guy's 05 sucks. With the mods listed, the most important thing to do is get tuned, but also, he should get a stock IX DV or JDM MR DV (same thing).
Hey, new guy, I know you said you're new, which is why you don't know anything, but when you're new, you're supposed to search. Yes, it has been discussed a million times, and since you know that, why didn't you go look for the answer? Be sure to do that in the future...
Old Jan 14, 2007 | 03:10 PM
+1
i just didnt feel like saying it
Old Jan 14, 2007 | 03:12 PM
C6C6CH3vo's Avatar
Stock DV is designed to taper
My OEM DV holds to whatever compressor can put out but had to severly modify it to do so in order to keep stock like drivability.
Just keep in mind that increasing DV or BOV holding ability also effects the car's drivability in a negative way
Forge rs is one of the good ones
Old Jan 14, 2007 | 03:13 PM
Originally Posted by C6C6CH3vo
Stock DV designed to taper
get a boost controller
Old Jan 14, 2007 | 03:26 PM
Warrtalon's Avatar
The BOV is not related to taper, and is not "designed" to taper. The stock bov is just weak - bottom line.
