JUN-Revolver-Cosworth Cams?
Old Jan 13, 2007 | 07:24 PM
GT35REVO8's Avatar
Im running the HKS 272 i/e cams right now..looking to upgrade to more aggresive cams when i build my motor,port head and get springs and retainers.i will most likely go with the 280s ,but from which company?ive heard great things about JUN..anyone want to chim in and let me know what would be best,running AMS 35R with built 2.0 soon.thanks in advance.
Justin
P.S. with me upgrading cams..HKS 272s will be for sale here shortly...
Old Jan 14, 2007 | 09:27 AM
Talonmotosports's Avatar
The jun 272 s have gotten great reviews
Old Jan 14, 2007 | 09:29 AM
do a search on this topic tho, i think it has been addressed several times on this forum
Old Jan 14, 2007 | 10:22 AM
sparky's Avatar
Originally Posted by GT35REVO8
Im running the HKS 272 i/e cams right now..looking to upgrade to more aggresive cams when i build my motor....i will most likely go with the 280s ,but from which company?ive heard great things about JUN..anyone want to chim in and let me know what would be best,running AMS 35R with built 2.0 soon.thanks ...
You have to be careful when you say that you will go with 280's from X company. Cam maufacturers measure duration differently, so that one manufacturer's 260* duration camshaft may be much more agressive, or "radical", than another manufacturer's 280* offering. Thus, as a practical matter, a JUN 264 has about the same effective duration as an HKS 280* cam.
I probably got it all wrong, but I'm just trying to caution you, that you should not assume that a 280 HKS cam is gonna behave the same as a JUN 280 cam.
Old Jan 14, 2007 | 02:31 PM
GT35REVO8's Avatar
i never said a hks 280 will perform the same as jun 280s...actually jun 272 will perform better then hks 280s from what ive heard...i was just saying that with whatever company i do choose to go with out of those 3 it will most likely be 280s
Old Jan 14, 2007 | 04:54 PM
Frenchy4g63's Avatar
Jun and Cosworth dont even make a 280 cam..
Old Jan 14, 2007 | 05:44 PM
GT35REVO8's Avatar
oh ok i figured they did,never really looked them up...probably gonna go with JUN 272s and springs and retainers as well when i do motor build soon
Old Jan 14, 2007 | 05:57 PM
Jakeg97's Avatar
272- revolver has a bigger lift than jun, but either one is your best bet
Old Jan 15, 2007 | 08:58 AM
Bruzewski's Avatar
The misinformation on this is terrible.
The cam sizes are:
Revolver Cams
Intake 262
Exhaust 264
HKS
Intake 280
Exhaust 280
JUN
Intake 272
Exhaust 272
And if you want Revolver good luck getting them.......
Old Jan 15, 2007 | 11:57 AM
Ted B's Avatar
It becomes misinformation when one attempts to use solely advertised duration numbers (e.g. 280, 264, etc.) as a basis of comparison for different manufacturers' cams.
The fact of the matter is that duration @ 1mm (or 0.050") is effective duration, and is a more realistic indicator of cam behavior. In reality, the JUN 264 appears to have about the same effective duration as an HKS 280. He who ***umes that a JUN 264 behaves like an HKS 264 will find out otherwise.
Terms like "280" and "272" are almost meaningless when comparing cams from different manufacturers, and Sparky's post above is 100% correct.
Old Jan 15, 2007 | 12:13 PM
Bruzewski's Avatar
My post was not directed at sparky. He was right on.
But when people say:
I have to say something.....
Old Jan 15, 2007 | 12:20 PM
Ted B's Avatar
Yes, well those are obvious blunders!
Here are relative effective duration figures for the cams in question. Note that my estimation for the JUN 264 (don't have the hard figure for that one) indicate it likely has more effective duration than HKS 280s or Revolvers.
HKS 264
Effective Duration 206 deg @ 1mm
HKS 272
Advertised Duration 214 deg @ 1mm
HKS 280
Advertised Duration 222 deg @ 1mm
Revolver
Effective Duration 222/223 deg @ 1mm
JUN 264
Effective Duration 228 deg @ 1mm (estimated)
JUN 272
Effective Duration 235 deg @ 1mm
Now, keep in mind these figures do NOT take into account lobe centerlines, which have a direct affect on power vs. rpm. With a set of cam gears however, that becomes a moot point, as one can set the lobe centerlines anywhere he likes.
They also do not take into account differences lift, which flow data indicates will have a greater effect on a properly ported head than a stock head (which is pretty much done by 10.2mm lift for both ports).
Old Jan 15, 2007 | 01:10 PM
yasir's Avatar
i needed help deciding on cams, and I went for Jun 264s based on Ted's recommendation!
Old Jan 15, 2007 | 01:26 PM
EVOlutionary's Avatar
I don't think PlayerZ was posting the "names" of the cams as a comparison of potential, but rather to inform the people who were talking about 280 Juns and 272 Revolvers and such that there is no such thing. Perhaps what he could have posted is this:
Im running the HKS 272 i/e cams right now..looking to upgrade to more aggresive cams when i build my motor,port head and get springs and retainers.i will most likely go with the 280s ,but from which company? . . . .
. . . . i was just saying that with whatever company i do choose to go with out of those 3 it will most likely be 280s
Obviously you don't know anything about these cams other than the names of the companies that make them. There is no such thing as a Revolver 280. There is no such thing as a Jun 280. Cosworth's M2 cam is the only "280" cam made out of the names you threw out, so I guess if you just want something with "280" in the name then your choice is very easy.
Now, if you decide that you actually want the cams that make the most power or allow faster spool of the turbo, then you have more research to do. . .
EVOlutionary
Old Jan 16, 2007 | 01:48 PM
mjo's Avatar
mjo
Please post a link to the review. I can't find them with the search
Thanks,
Maurice
