CEL Light : EGR Insufficent air
Old Jan 14, 2007 | 04:14 PM
  #31
Evoryder's Avatar
Originally Posted by jjm4life
sort of on topic, i am having a similar issue.
i just got my car back and its pulling an egr code (p0401). the dealer told me they are reaplacing the entire egr solenoid, so i am driving around with the cel.. they said im alright, but what do you all think?
THAT IS THE CODE THAT MEANS YOUR HOSE POPPED OFF THE NIPPLE...READ WHAT WE HAVE BEEN TYPING TO SEE IF YOUR HOSE SLIPPED OFF THE NIPPLE...
sorry for the caps...actually, i'm not.
ez fix
Old Jan 14, 2007 | 04:35 PM
  #32
EVO-8-YOU's Avatar
i put the line back on the nipple zip tied it like you guys said. fixed it a little bit if i boost 21 it will fuel cut . but if i put it at 19 its fine. .what do you guys think ??
Old Jan 14, 2007 | 05:13 PM
  #33
Evoryder's Avatar
clear the code / reset ecu...
are u stock?
Old Jan 14, 2007 | 05:28 PM
  #34
jjm4life's Avatar
the dealer said the hose and the solenoid are both trashed.. probobly from the accident or the clutch installation, so its all covered under warranty
Old Jan 14, 2007 | 05:30 PM
  #35
boostingevo8's Avatar
Originally Posted by QwikSRT4
You will be fine. The EGR valve is only for emissions. Many owners of other cars have removed their EGR valves with no ill effects.
I drove around for months with my CEL on because I gave up on figuring out what the problem was. Then I did a search on here and found out what the problem was....and lo and behold the vacuum line kept popping off the EGR valve nipple.
Dude props for handling those childish/brainless comments in a mature manner!
Old Jan 14, 2007 | 05:32 PM
  #36
Evoryder's Avatar
ok...
...covered under warranty ...you're good 2 go
Old Jan 14, 2007 | 05:37 PM
  #37
QwikEVO's Avatar
NP, thx.
