cosworth isp head flow numbers
These are the numbers that I have
Intake flow at 28.0"
Lift_________Stock________Cosworth
.050________47.5__________47.4
.100________87.5__________93.6
.150________130.9________139.0
.200________168.7________178.9
.250________199.2________211.2
.300________219.3________238.8
.350________230.1________258.3
.400________220.9________268.9
.450________224.2________274.6
.500________226.5________277.6
If he posts the stock flow #'s I can see if the delta from stock to Cosworth is the same. It should make little difference that they have been flowed on seperate benches. If the numbers are close then his gains can be verified on a seperate bench giving his results further credibility.
I'm sure they were. I was referring to 240Z TwinTurbo's post that showed the Cosworth head had better flow numbers than what you posted. I wanted people to know that the exact same head on 3 different benches will post 3 different results.
Holy crap! 9KRPM! Is that a 2.0 or is it stroked? Also, do you have a torque curve to go with this?
It would be useful to post the modifications to your head (valve sizes, for example) to permit direct comparison between, for example, Cosworth valve sizes and what your using. Some rough comparison of cost would also be helpful. Thanks.
We use supertech valves. Price will be comparable to the cosworth head. Peter
