View Poll Results: what clutch street/strip
act
66.67%
exedy stage 2/3
22.22%
other
11.11%
Voters: 9. You may not vote on this poll
clutch and turbo manifold questions
Old Jan 20, 2007 | 09:02 PM
scoob4fun's Avatar
so anyone else out there running this set up with the Gruppe flywheel/ACT clutch? How is the pedal pressure/feel? Clutch engagement?
Old Jan 20, 2007 | 10:28 PM
t51splbb's Avatar
The flywheel will not change the pedal effort on the clutch,so it doesn't matter if the flywheel is the ACT, Gruppe S or stock. The pressure plate is related to the pedal effort and the disc combined with the pressure plate will affect how the clutch engages. The ACT HDSS pedal effort and engagement have been both disscussed at length numerous times.
Old Jan 21, 2007 | 12:44 PM
scoob4fun's Avatar
I was more interested in how the two components work together and if there was anything negative I should know about. Im aware the pedal pressure has been discussed numerous times (Ive searched through the treads) but I didnt know the mechanics of the clutch and if the flywheel would effect that. Some times I think people on these forums just love to jump on people who may not know as much as them.....
Old Jan 22, 2007 | 03:39 PM
Gruppe-S's Avatar
For the main difference that I see between the ACT flywheel and the Gruppe-S flywheel has a smoother engagement surface so it takes a bit longer to break in than the ACT unit. After break in, I personally prefer the Gruppe-S flywheel over the ACT street.
Cheers,
Gary
Gruppe-S
Old Jan 22, 2007 | 04:48 PM
ACTman's Avatar
Gary,
Smoother engagement surface? A flywheel needs to be broken in? Uhh...?
I guess as long as it is mated to an ACT clutch, it's all good. ; )
Old Jan 22, 2007 | 08:36 PM
scoob4fun's Avatar
Thanks for chiming in guys.
Old Jan 22, 2007 | 09:20 PM
Gruppe-S's Avatar
Originally Posted by ACTman
Gary,
Hi Dirk,
That's what we're seeing with our flywheels. They work great with your ACT evo clutches!!
Cheers,
Gary
Gruppe-S
Old Jan 22, 2007 | 10:35 PM
Danny23's Avatar
I have the ACT MB7-HDSS with the ACT prolight flywheel.I have about 1200 miles on it and absolutely love it. Stock like engagement(smooth as glass) not a sound coming from it under any conditions,and the car launches like a rocket without a hint of smell(if done right of course). I was told it might be to light(the flywheel) for a good ez launch and i might get high rpm lockout. None of this is true. The peddle pressure feels much better than stock,it grabs at the same point everytime, and the car shifts as smooth as can be even at 7800rpm,s. I would recommend this clutch and flywheel to anyone.
Old Jan 23, 2007 | 09:33 AM
Talonmotosports's Avatar
ACT all the way. Best bang for buck
Old Jan 25, 2007 | 07:08 PM
evilevo22's Avatar
is there any clutch thats stronger and will last longer then the act around the same price. Just wanna make sure i dont make the wrong descision on a clutch.
Old Jan 25, 2007 | 08:23 PM
ACTman's Avatar
Our XTR6 kit (Xtreme p/pl, solid center 6 puck) is a lot stronger and probably less expensive, but it is also harsh engaging and overkill as most race clutches would be. Whatever clutch you choose, get the right one for the job.
Old Feb 6, 2007 | 05:46 PM
evilevo22's Avatar
ok i was thinking about getting the ACT xtreme street clutch kit because most places are sold out of the hdss but am looking for opinions on this how does this clutch engage, is the pedal effort too stiff for everyday driving ect..... thanks
Old Feb 6, 2007 | 08:40 PM
evilevo22's Avatar
bump
Old Feb 6, 2007 | 09:03 PM
badhabit90's Avatar
Cool
Originally Posted by evilevo22
ok can i get a link to PORT AND POLISH MANIFOLD
http://www.paradigmperformance.net/p...evo/index.html
scroll down and check out the options. ALOT less than buschur..
Old Feb 6, 2007 | 09:09 PM
riceball777's Avatar
i'm also looking at the act xtss. everyone here has the hdss.
how will the xtss hole up in a gt3076r setup. 400whp daily and about 500whp on race gas
