View Poll Results: what clutch street/strip
act
66.67%
exedy stage 2/3
22.22%
other
11.11%
Voters: 9. You may not vote on this poll
clutch and turbo manifold questions
Old Feb 6, 2007 | 10:30 PM
  #31
evilevo22's Avatar
any info on xtss buying a clutch tomarow
Old Feb 7, 2007 | 08:11 AM
  #32
ACTman's Avatar
The difference between the HDSS and XTSS is only the clamp load of the pressure plate. Since the increase in clamp load is generated through a change in fulcrum points as well as a stronger diaphragm, the difference in pedal effort between the two is not much. The engagement quality should be identical (smooth, quiet, possibly slight chatter at low rpms in first/rev). Engagement quality is mostly affected by the disc design and materials and little to do with the pressure plate.
