View Poll Results: 02 housing?
install the aftermarket 02
43
82.69%
leave the stocker
7.69%
sell the helix and port and coat the stocker
9.62%
Voters: 52. You may not vote on this poll
Input on an 02 housing on a IX
Old Jan 17, 2007 | 10:29 AM
kreionic's Avatar
OK I have been to a bunch of shops around my area and I keep getting different answers. Any IX owners with stages I-III please chime in. Half of the shops say put the 02 housing in the other half says its not worth it. I already have a helix 02 housing. I just haven't put it in yet. So I would like some input from IX owners that have done this to tell me what they think about the 02.
Old Jan 17, 2007 | 10:30 AM
deadbeatrec's Avatar
yes its worth it.
Old Jan 17, 2007 | 10:34 AM
TouringBubble's Avatar
I've heard that the O2 shows more gains on the IX than the VIII, but I"m not sure how reliable the information is. Go for the aftermarket though ... smoothing the collision with the WG dump has to make a difference, whether you can feel it or not. It will show on the dyno.
Old Jan 17, 2007 | 11:19 AM
dafunk630's Avatar
yes it is worth it. i went with the ss autochrome ebay o2 housing
Old Jan 17, 2007 | 11:22 AM
Reefer650's Avatar
the best thing you can do for your engine is let it breath
Old Jan 17, 2007 | 11:23 AM
bvdawg13's Avatar
it also depens on the future plans for your car, if your gonna be doing a turbo upgrade, most will come with or require a new o2 housing so keep it in mind
Old Jan 17, 2007 | 11:27 AM
Warrtalon's Avatar
Kreionic, I can't imagine any shop with half a clue saying not to install that. Whoever says that has very little clue about the Evo, imo. It also means they haven't seen the back-to-back dyno testing of that o2 versus not only stock but other aftermarket housings that cost way more. It won in every scenario.
And especially, if you already have, I can't even imagine asking us if you should put it on. If you didn't have it, we'd say to buy it, but when you already have it, it's a no-brainer. I would almost bet that one of the shops that said it's not worth robably believes it's worth it for you to buy a $400 tubular manifold, too, instead of porting the stocker for less than half the price.
Old Jan 31, 2007 | 10:33 AM
boomn29's Avatar
Bump for 02 Housing gains on a IX. Anyone know specificially what to expect? Just a small bump throughout the range or on throttle response?
Old Jan 31, 2007 | 10:37 AM
fastrob691's Avatar
Personal experience, I have the Helix o2 housing on my IX, we dyno'd before and after no other changes to the car and no tuning for the 02, just dyno, bolt on, dyno, we saw an 8ft-lb peak tq increase, no increase in peak power, and about 200-300 rpm lower spool up point when comparing boost graphs. This was on a mustang dyno and the car already had test pipe/cat back helix exhaust. Bottom line, better spool, better lowend.midrange tq. I have never experienced boost creep or any other problems and I run a Hallman MBC. Hope this helps
Old Jan 31, 2007 | 10:57 AM
EVIL_EVO_VIII's Avatar
Buschur dynoed this piece and picked up 12whp and 11wqt
Old Jan 31, 2007 | 11:14 AM
FiftyFive's Avatar
Would these be similar between the Helix Housing and the Ebay housing?
Old Jan 31, 2007 | 11:19 AM
Yes, theyre both pretty much the same
Old Jan 31, 2007 | 11:39 AM
bboypuertoroc's Avatar
Veteran: Army
Get the eBay O2. You can find them for as little as $30.
EDIT - N/M, saw you got the Helix... put it in. If a shop is telling you it's not worth it then they're full of **** and shouldn't speak of Evo's.
Old Jan 31, 2007 | 11:42 AM
shivaswrath's Avatar
what about the Invidia 02 Housing? Same idea? Same construction as the helix and ebay?
I've decided there is no point to the WORKS housing, despite it's superior cast construction, it looks like the other housings bolt up just fine. . .
Old Jan 31, 2007 | 11:47 AM
HOSTILE_EVO's Avatar
my ONLY hesitation with the aftermarket is that you loose that factory support bolt that straps the O2 housing to the block.
