help!!! NEED TO KNOW WHAT CLUTCH TO GO WITH!!
Old Jan 17, 2007 | 06:29 PM
rraulston's Avatar
Originally Posted by hondafan
well, do you want a comfy clutch in traffic or one that's gonna hold 450whp and hold up for a while?
^^+100^^
Old Jan 17, 2007 | 06:32 PM
frenchy99's Avatar
so you're saying the stock clutch will take 400-475whp reliably and last just as well as an aftermarket unit?
Better then an ACT clutch. Remember that a stock clutch can hold up to 400whp. The stock Clutch is a EXEDY ORGANIC. I seen a vendor that was selling a stock clutch The stats said that it will hold 400 WHP.
WrX Kila's Avatar
Originally Posted by dafunk630
what clutch combo do u have in ur car??
ACT... I think the disk is getting low, I have to shift slow when I race the car. When it was newer I never had that problem. I went thru 3 turbo's with the same clutch. stock, 3076r and now a 35r.
Old Jan 17, 2007 | 06:33 PM
dafunk630's Avatar
rraulston how is th ACT XT-SS for daily driving???
Old Jan 17, 2007 | 06:36 PM
E VOL IX's Avatar
O dude it is awesome.. like i said it engages just like stock.. just with stiffer feel and it grabs smoother.
Old Jan 17, 2007 | 06:38 PM
dafunk630's Avatar
u went with prolight or streetlight flywheel???
Old Jan 17, 2007 | 06:47 PM
kouzman's Avatar
This is the setup that i want to get for my car probably along with the pro-lite flywheel. I think price-to-performance is unbeatable!
Now about the stocker...i have 5350 miles on the clutch. MANY highway miles, launched only once, but now with the 337/342 on a DD it cannot hold the abuse, leave alone if i use the high boost (373/422) with C16 mixture... The stock is good but at these power levels there is no way to hold with hard driving...
Old Jan 17, 2007 | 06:51 PM
03silevo's Avatar
exedy twin disk hd all the way best street strip combo
Old Jan 17, 2007 | 06:53 PM
rraulston's Avatar
Its o.k. Ime at 459 to the wheels and can burn the he!! out of it if ime not carefull. Had to really adjust the pedal cause of the famous ACT lockout. If i could do it again, i would have went Exidy twin. I have installed 20 or so clutches, and those twins are all i recomend for over 400hp and a stock/exidy race(silver pressure plate/organic disc) for under. Tiltons have been fixed and are nice pieces. Hard to install however. Exidy singles(1/2 of the twin) for $900 are a waste. ATS carbon/carbon...$$$$$$. Bottom line.....twin or oem.............ray
E VOL IX's Avatar
I went with the streetlight..it weighs 13lbs i think. the stocker is light anyways but you dont wanna go too light for everyday b/c then rollin through traffic is gonna suck.
Old Jan 17, 2007 | 06:57 PM
C6C6CH3vo's Avatar
I'm not close off your torque and so far the excedy stage 1 is doing fine with one launch, and that was for $350. I admit I did cut it close but it was purely economical
Also keep in mind the higher the torque and lower the rpm - the stronger your clutch needs to be
Old Jan 17, 2007 | 07:26 PM
hondafan's Avatar
there is a vast difference between the exedy OEM organic clutch and the exedy stage 1 organic clutch. they look almost the same, but hold different levels of power. i'm thinking the vendor had the exedy stage 1 organic clutch for 400whp.
Old Jan 17, 2007 | 07:31 PM
hondafan's Avatar
Better then an ACT clutch. Remember that a stock clutch can hold up to 400whp. .
you are mistaken, trust me.
Old Jan 17, 2007 | 07:45 PM
djakarta's Avatar
Good luck with your search! I got ACT 6 puck sprung and am loving it so far. This topic has been covered hundreds of time so you might want to do a search. One thing that you need to keep in mind is there's always pros and cons on which clutch that you pick. For example,
ACT HDSS
Pros: The most popular clutch under a $1000, rated for 400+ HP
Cons: Lockout issues and needing adjustments frequently (ask TTP and ACTman why!)
Exedy HD
Pros: The most popular clutch over a $1000, rated for 600+ HP, somewhat easier to drive and quieter compared to the SD version
Cons: It's still noisy , you'll end up paying almost 2 grand with cost of install
Tilton Twin Carbon/Carbon:
Pros: Probably the most popular clutch over $2000, rated for too many horses
Cons: It's more than 2 g damnit!!!
Another alternative is to wait for a good deal for a used twin plate clutch and have it rebuilt. Sometimes people sell their used twin plate for around 300 dollars. The cost of a rebuild is probably around 500. So you get the best of both world. Under 1 g for a twin plate
Old Jan 18, 2007 | 11:15 AM
dafunk630's Avatar
ACT HDSS
Exedy HD
i heard that the six sprung disk it sucks bumper to bumper traffic is that true??? and also i heard it makes noise is this true???
