Helpppppppppppp
Old Jan 20, 2007 | 05:47 AM
chaz517's Avatar
Helpppppppppppp
I'm under my car rite now n on ym fone, imk tryin 2put on my new exhaust. With the new downpipe do I use the same bolts with the springs as the stocker?! Rhanks
Old Jan 20, 2007 | 05:56 AM
ak47po's Avatar
learn how to spell.
Old Jan 20, 2007 | 06:05 AM
steevo's Avatar
Chill man.....I used the stockers with springs. You should be OK.
Old Jan 20, 2007 | 07:15 AM
EVO8904's Avatar
1+ you will be okay
Old Jan 20, 2007 | 07:58 AM
chaz517's Avatar
I can't get the 2nd spring bolt in I got the oneon the right in and it seems like the other one is xentimeters short of reaching the hole I'm gett mad its been 4hours lol and I'm still on the flippin downpipe
Old Jan 20, 2007 | 08:07 AM
Robevo RS's Avatar
home depo!
get those screw and go there ,get longer ones.
in 4 hours you can do this trip at least couple of times.
or try to get the "smaller" one first ,/unscrew the easy one/and then try to go thru with the easyone. you are alone there? or use the zipptie to compress the springs /2-3 of them /. then put it back and try like that!
andyktlee's Avatar
Pocket Mo
Loosen the other one and get that 2nd bolt in. Never have one side bolted in completely before the other side.
Old Jan 20, 2007 | 08:09 AM
Psquared's Avatar
^^ true, I just did my catback, and used vice grips to close the flanges enough to get the bolts thru with little to no effort. Obviously use some rags to not marr up the flanges.
Old Jan 20, 2007 | 09:44 AM
nk1124's Avatar
if the downpipe isnt going on all the way, make sure you havent left the donut gasket on the car, that would prevent the downpipe from fitting right
Old Jan 20, 2007 | 10:04 AM
LoCo4's Avatar
+1
Old Jan 20, 2007 | 10:09 AM
reggiesd's Avatar
yeah...it took while took put in those 2 bolts on the downpipe..you just gotta keep on it.
oh and i think he was using his phone to post his question when he did this guys..that prolly explains the "spelling" issue.
Old Jan 20, 2007 | 11:30 AM
TxEvo8's Avatar
+2, check for the donut. I used the stock spring bolts and ended up loosing both of them after almost a year, so I put in the ones that came with the kit.
Old Jan 20, 2007 | 11:54 AM
chaz517's Avatar
Lol yes I was on my phone using my sidekick, I can't believe some 1 said watch your spelling when I stated I was literally under my car at the time lol but its all good now, sor for the outburstm and wow it took 4 freakin hours to get my downpipe on properly, what a nightmare, so I have that and the test pipe for now cuz I need a break lol but thanks to everyone who helped me out with this I really needed the help and apprecaite it thanks
Old Jan 20, 2007 | 12:02 PM
EVOL EDO's Avatar
its ok next time you put on a dp it will only take 30 minutes. took me 4 hrs the first time for my exhaust too. but i had to walk to the gas station to get my dp drilled so it fit the cat so that took a little longer. and it was like 20 mins getting the o2 off that thing as damn tight.
Old Jan 20, 2007 | 12:32 PM
chaz517's Avatar
Lol at least I'm not the only one, and its funny everrrrrryone said the o2 senor was the hardest part, but I swear its been the easiet thing I've done on my exhuast, it was harder finding the 22 mm wrench then getting it off lol I guess I made up for the hard part in the dp
