heat wrap downpipe.
Old Feb 1, 2007 | 10:26 AM
  #31
boostedwrx's Avatar
Just coat it. www.performancecoatings.com or 900 other sites. Got mine coated for $45 and I can touch it after I drive.
Old Feb 1, 2007 | 10:39 AM
  #32
deadbeatrec's Avatar
Originally Posted by KevinD
uh huh. keeping the heat inside is why you heat wrap it. keeping the heat inside the manifold will help the turbo spool faster. and i doubt you have seen any quality manifolds crack for the sole reason it was heat wrapped. more then likely there were a number of other reasons, such as an unsupported turbo, or to thin of tubing.
ironically, wrapping the downpipe i can't see a reason to do. i've tracked my car many times, without a heat wrapped downpipe and never had any problems at all with overheated oil.
oh, and before heat wrapping the mani, i thought the radiator hose was going to melt it was so hot in the engine bay after a 30min track session. after wrapping it, i could literally touch the header immediately after a 30 minute session. engine bay temps dropped enormously. next time i need to wrap my manifold, i'll be sure to log some temps.
maybe it was due to moisture?
Old Feb 1, 2007 | 12:07 PM
  #33
KevinD's Avatar
prolly not. the manifold opperates at 1000 degrees+ at WOT. even at idle it operates at 3-400. water boils at 213 deg. therefor, even after idling for a minute or so, all the water has been boiled off (even if you have a saturated heat wrap), the manifold will be dry any time it is at operating temperatures. so explain to me why moisture would cause it to crack?
do exhaust pipes crack when you drive in the rain? they are hot, and they certainly get when when it it rains... why would the wrap make any difference?
Old Feb 1, 2007 | 12:47 PM
  #34
KartaRailed's Avatar
There are different schools of thought on this one. The main reason I see for cracking in the rain with exhust manifolds are as follows. Most people who run a manifold run an aftermarket o2 housing as well. With the ebay o2's there is no longer a suppourt brace on the o2 housing to hold the weight of the turbocharger up, thus putting stress on the hot (1000+ degree) exhaust manifold, the metal is already weakend by this, then rain water coming thorugh a hood vent with no black metal vent insert gets on the manifold, causing fluxuations in temp. which then results in cracking.
Old Feb 1, 2007 | 01:39 PM
  #35
KevinD's Avatar
i would agree with this plus, the heat wrap can actually act as a barrier from direct water on the hot manifold. athough i wouldn't expect the rain effecting the header while it is running, i could see it happen once the car is turned off after being extremely hot, the rate of thermal expansion could be really high if you splashed water on it, thus cracking it. the wrap isn't going to make a difference with or without it in this case though.
shomesomesho
Oct 29, 2016 10:04 PM
EvoJedi77
46
Feb 5, 2009 03:05 PM
DrunkMunkyStyle
22
Aug 27, 2006 02:01 AM
yesevo
28
Sep 8, 2005 01:20 PM
RichJ
21
Feb 29, 2004 03:51 PM
