20G-LT Camshaft options....
Old Jan 24, 2007 | 07:37 PM
vmsturbo's Avatar
So i am basically BR stages 1-4 and am deciding what camshafts to run with my 20g-lt. I'm a little torn between the S1's and Cosworth. Both have shown pretty good results, but i'm trying get some responses from those who have a similar setup to let me know the likes and dislikes. Please keep in mind i'm in california so i have to use meth to compensate the ****ty 91 octane. With that said i'm already aware i will not get that high of numbers, plus i'm running a hi flow cat. My overall goal would be 400 whp.
Old Jan 24, 2007 | 08:55 PM
jbrown's Avatar
I'd like to ask the same question, but on an VIII instead of a IX.
Old Jan 24, 2007 | 11:44 PM
gudmundur's Avatar
I am on the same boat, trying to figure out what cams to run on my VIII.
I already sent Greg at GSC an e-mail asking his opinion and he basically pointed me
Old Jan 25, 2007 | 02:53 AM
ONRAILS's Avatar
I'm running GSC 280's Because they seem to have a very good powerban.. nice idle.. and really good quality.
Also no need to install springs/retainers.
Old Jan 25, 2007 | 04:50 AM
sparky's Avatar
On my VIII I am running HKS 280/272 with my TME, and will initially keep that combo when I change over to the FP EvoGreen, however, I may eventually switch cams over to something like the JUN 264's. It will be interesting to see comparative dyno results on the 20G-LT as they begin to appear, with the different cam options, such as the Revolvers, JUNS, HKS, Cosworth, and etc.
Old Jan 25, 2007 | 07:16 AM
PPI's Avatar
PPI
On a VIII with a stock head I would run HKS 280's or try the JUN 264's. If you had a built head along with AEM and wanted maximum power you could look into something like the JUN 272's which would be a extreme setup.
Old Jan 27, 2007 | 03:49 PM
RanEvo's Avatar
If you have VIII, go whit the Pipers BP285, you will get tons of torque.
Old Jan 27, 2007 | 10:15 PM
Zeus's Avatar
Here's an idea... ask Buschur or Forced Performance. At this point, there are a lot of educated opinions, but few actual results regarding the "best cams" to use with this turbo. The math may add up, but it does not always translate to the pavement.
Old Jan 27, 2007 | 10:42 PM
DRFTKNGG's Avatar
Love my HKS 280's, great powerband with IX turbo.
Old Jan 27, 2007 | 10:50 PM
EVO8URV8's Avatar
I got GSC's on my VIII, loving it. (so far)
Old Jan 27, 2007 | 11:03 PM
DRFTKNGG's Avatar
Sorry..... VIII as well.
Old Jan 28, 2007 | 02:40 AM
kjewer1's Avatar
I run the HKS 272s with the Green/20g-LT. However, I have not tried any other cams with this turbo on this car to compare to, so I won't make a worthless recomendation that is merely opinion and not based on test results.
Old Jan 28, 2007 | 04:47 AM
nix's Avatar
nix
Based on test results (392WHP / 401 WLb-ft) with 'Gen1' TD/Evo400 BB turbo
I agree with RanEvo.
Looks like "more airflow + moderate duration + higher valve-lift = more mid-range torque." No firm results yet with EvoGREEN but for AutoX, I'm going to try Piper's Ultimate Road or their Rally cam kit first.
Old Jan 28, 2007 | 07:49 AM
evowilling's Avatar
What are the Piper camshafts equivalent to or in the same league with?
Old Jan 28, 2007 | 09:39 AM
4G63>OOOO's Avatar
I swapped in the Revolvers over the HKS 272's that I had before and there is a significant torque increase in the mid range.
