Clutch pedal vibration????
Old Jan 24, 2007 | 11:53 PM
just a neon's Avatar
I just had an ACT clutch and Gruppe-s flywheel installed. When the car is not moving and I barely press the pedal in no more than an inch I can feel vibration through the pedal. I did some searching and found quite a few people experiance this but could not determine if it is normal or a problem. The car drives and shifts fine. I only have 150 miles on the clutch so its still not broken in yet. So can someone please tell me if this is normal?
Old Jan 25, 2007 | 11:09 AM
anybody????
Old Jan 25, 2007 | 12:10 PM
OwnedEvo10's Avatar
I had this problem when i got my car back from the bodyshop when i got in my accident....It was my slave cylinder...What happened was coolant got inside and rusted the internals and was causing vibration in the pedal...So i changed it and everything was fine after that...Hope this helps....
Old Jan 25, 2007 | 12:17 PM
elhalisf's Avatar
This happened to my friends car before the Throw out bearing broke off from the pressure plate. however, this was after 40k of driving on the exedy stage 1 clutch kit.
but, i would check the slave cylinder bolts and see if they where tight.
Old Jan 25, 2007 | 08:34 PM
EVOla_VIRUS's Avatar
same deal here with an exedy twin disk carbon....this is my second carbon and didnt have the vibration on the last car.
icy_comet
Apr 8, 2016 11:32 AM
fanbelted
Jul 3, 2009 08:23 AM
silverevo05
13
Nov 5, 2007 07:07 PM
deegaw11
13
Feb 27, 2007 12:20 PM
smokey
10
Dec 18, 2006 03:22 PM
