Timing belt change
Timing belt change
Ok I did a search but I did not find exactly what I was looking for..I have to change my timing belt pretty soon and I was thinking well since its time I might as well get a set of Greddy gears and belts. My question is on the stock cams, what deg. setting would help out with increasing the torqe. Also which settings would increase peak HP? I have not decided which one to use yet..I had considered trying a -3, -3. Any input would be appricated.
edit..forgot 03 evo.
around reno NOPE..only 2wheel dyno's here..N. cal..closest awd dyno would be Bay area perhaps. (does shiv have one?)
Testudo..this is only the start..I have more plans and a tuning path in mind..I figured to get them now so I don't need to bother later.
If you still have stock cams dont worry about gears especially if you cant dyno. Change the cams before you even begin to worry about gears.
BoostLover99
Dec 4, 2009 05:01 PM
