Evo 9 w/ 20G-LT, S1 GSC cam + bolt on round 2
Old Feb 4, 2007 | 07:36 PM
  #31
SWOLN's Avatar
WAY more power left but the EBC wasn't allowing for more boost.
What EBC are you using?
Old Feb 4, 2007 | 07:38 PM
  #32
Aby@MIL.SPEC's Avatar
can you post a compare of old mods vs new mods on 91 octane?
Old Feb 4, 2007 | 07:43 PM
  #33
Jim in Tucson's Avatar
Birdie,
Please point me to your full list of current mods.
Thanks,
JiT
Old Feb 4, 2007 | 09:54 PM
  #34
MR. Birdie's Avatar
I have the HKS EVC, the reason why My EBC didnt allow more then 24.5psi is because i'm running the stock evo 9 wastegate actuator. The EBC can only boost double the wastegate spring setting. Once I upgrade to the HP actuator, i'll be able to boost 30psi.
Here the graph of the old mods vs new mods.
Old Feb 4, 2007 | 10:00 PM
  #35
Erik@MIL.SPEC's Avatar
Interesting. The temp is almost 25 degrees colder in your older run, and you made that much more power with just an intercooler and testpipe.
Old Feb 4, 2007 | 10:08 PM
  #36
RSGuy's Avatar
Originally Posted by alan678
Only 24.5 lbs on 110 octane....man, that was a waste of dyno time, but impressive numbers none the less!!! Need to strap on a MBC and crank up the boost!!!
Dude, stfu. So what if he doesn't want to risk blowing up his stock block...
Old Feb 4, 2007 | 10:23 PM
  #37
Peteypab2133's Avatar
Not to defend , but is that not the purpose of this turbo? to max it out without having to worry about building the bottom ends of our cars.. I thought from others experiences that the stock blocks were good to over 500 whp.. didnt think this turbo would push that limit.
Old Feb 4, 2007 | 10:41 PM
  #38
MR. Birdie's Avatar
If you read my post above then you nkow why it was limited to 24.5psi.
Old Feb 4, 2007 | 11:10 PM
  #39
RSGuy's Avatar
Yeah, there are cars pushing OVER 500whp on the stock blocks. But I guarantee you would not be able to beat on those cars daily (as in high-rpms/highway pulls/racing) w/o it blowing up very soon. I wouldn't subject my stock block to anything over 25psi, even w/ a stockish turbo, until I knew I had the money for a new built block. David Buschur has said in the past that he doesn't recommend pushing the stock block past 25psi and considering how much experience he has with our motors, I trust his advice. For some reason some people on this forum think our bottom-ends are akin to Al Pacino in Scarface. However, the horsepower world is not yours (w/ a stock EVO block) and will blow up.
Old Feb 5, 2007 | 05:12 AM
  #40
3000ways's Avatar
Originally Posted by Jim in Tucson
Birdie,
Thanks,
JiT
These are his mods I believe-
Burschur TBE with test pipe, RC 780CC, 255lph pump, Injen intake, Burschur LICP, Burschur 02 housing, Burschur 20G-LT, GSC S1 cams, Blitz Intercooler, and Tuning Technologies Tuning
Old Feb 5, 2007 | 05:21 AM
  #41
Mad_SB's Avatar
Interested to see how the ebc handles the hp actuator... the few cars I have seen running the hp actuator and mbc had a midrange creep (couple psi at least) that forced a little lower boost at peak torque to prevent overboost in the midrange.
Should be able to tune that right out with the ebc.
Nice numbers.
Old Feb 5, 2007 | 07:29 AM
  #42
MR. Birdie's Avatar
Yup that's basically my mods.
Old Feb 5, 2007 | 07:51 AM
  #43
SWOLN's Avatar
MR. Birdie Just a thought but you might also try the Forge piston type actuator, either way after, I would seek out TURBODAWG. His ideas have some validity as far as wastegates go, to me anyways.
As far as 25 psi on stock blocks and all that, If the motor can perform in the correct enviornment, then the only limiting factor would be part integrity, just my 2 cent.
Old Feb 5, 2007 | 08:26 AM
  #44
milo's Avatar
Congrads on putting down some awesome numbers
I can't wait to get this turbo upgrade.
Old Feb 5, 2007 | 09:01 AM
  #45
MR. Birdie's Avatar
Thanx guys. I'm currently looking into a 65MM throttle body and Meth injection kit. How much power can a ported exhaust manifold actually give ?
