Big Problem
Old Feb 11, 2007 | 08:13 PM
  #46
kmcconn9's Avatar
So I think I figured out the problem with the hesitation, poor idle, and running lean.....I bet ny MAF is bad. I acdientally dropped it a couple times when I was working on the car early in the morning...oops...I didnt think much of it then as it was bolted to the intake/filter...
If I had a donor I could swap it out and see, but I dont have one laying around.
There isnt an easy way to tell if it is bad is there? I have a pocketlogger which I use for datalogging, unfortunantly that wont read the maf signal..
Old Feb 12, 2007 | 12:52 PM
  #47
kmcconn9's Avatar
UPDATE: Just got back from AMStuning....
First let me say a BIG thank you to Mike from AMS and his help this morning for getting me taken care of...customer service with AMS is always a pleasure!
It turned out that the lean condition was caused by a lower output pump for the alcohol kit that I just got swapped out. Which resulted in lower alcohol output. Thus making the car run lean.
Now the injectors are completly maxed out (680s) and I will have to upgrade them and get the car retuned.
Old Feb 12, 2007 | 12:54 PM
  #48
kmcconn9's Avatar
I am getting a mixed concensus on what the largest injectors are that you can use with the stock ecu and flash without risk...
So I am looking at 720's maybe, or the EMS..
Any insight on this would be greatly appreciated..
This is my 100% daily driver with no other means of transportation..
Old Feb 12, 2007 | 01:14 PM
  #49
PVD04's Avatar
You can run 1000cc without much issue. That's what I'm currently running with the stock ECU.
-Paul
Old Feb 12, 2007 | 04:46 PM
  #50
kmcconn9's Avatar
I am going to put this in a thread by itself. I think this thread is beat...
FoxFMX
Apr 21, 2024 03:42 PM
onlynamenotused
15
Oct 13, 2018 11:48 AM
TheDudeAbides
May 12, 2013 09:16 PM
IzzyRS
35
Feb 22, 2012 06:34 AM
evojoe90
Apr 18, 2009 02:28 PM
