Smoke at idle
Old Apr 17, 2009 | 05:44 PM
evojoe90's Avatar
Smoke at idle
My car smokes white/blue smoke at idle at first start up and at normal running temperatures. But when im WOT or driving normal it doesnt do it.. Its not burning oil because i check every week and its at the same level. Im running catless so.....? Help if u can.
Old Apr 17, 2009 | 05:50 PM
BenJ's Avatar
sounds like oil to me if it is blue. If it is white then anti-freeze or whatever you have in your radiator. Check your coolant level.
Old Apr 17, 2009 | 05:59 PM
EvoIIIAj's Avatar
Mine use to do the same, think it was my valve seals, after I changed my head and put in new ones it has stopped.
I got an EvoIII though.
Old Apr 17, 2009 | 07:35 PM
barneyb's Avatar
If you are not using oil and not losing coolant then it must be products of combustion whatever it looks like. If you don't like it the solution is to run a cat.
Old Apr 18, 2009 | 12:37 PM
evojoe90's Avatar
if it were valve seals then would it make any odd noises at idle? such as tapping or clicking? and when i have a cold start the car runs like **** for a couple of seconds...so i pulled the plugs and one of them were wet with oil. so i took a flashlight and looked in the spark plug hole and i can see oil on the top of the piston.
Old Apr 18, 2009 | 02:28 PM
barneyb's Avatar
Valve seals are made of rubber and they don't make noise. The usual signs of bad valve seals are a puff of smoke at start and hazy exhaust at idle.
W0LF
17
Sep 1, 2017 12:40 PM
Kkamshi
Aug 18, 2013 08:03 PM
evotuner1021
14
Oct 9, 2012 08:43 PM
Babs
Feb 10, 2010 07:35 PM
06FQ360
Jan 5, 2008 01:45 PM
