Rear Diff???
Old Feb 6, 2007 | 01:38 PM
tseitz123's Avatar
should i just go and get a new Cusco one? they're like $1100.
Old Feb 6, 2007 | 01:44 PM
4WS Tuning's Avatar
Originally Posted by razorlab
If that diff has AYC it will not fit.
opps i didn't realize it had it.. i was shopping for the headlight and tail light tint covers and saw it.
sry! thought i was doing a deed!
cheers!
Old Feb 6, 2007 | 01:52 PM
RoadSpike's Avatar
The only question I wold have here is if the cusco one came with new gears. That crunching sound probably means broken gears and so forth like a ring gear getting stripped or something.
I did a quick look around at some shops like Sheppard and TRE to see if they did a rear differential upgrade and couldn't find one . Makes me wonder how often the rear diffs go..
Old Feb 6, 2007 | 05:13 PM
EVOlutionary's Avatar
Before worrying about the Cusco, find out if it is just the ring and pinion (inside the "outer" housing) or if you actual LSD itself (inside the "inner housing") is damaged.
Only once you know what is broken can you figure out what parts to buy to fix it. . .
EVOlutionary
Old Feb 7, 2007 | 01:16 AM
RoadSpike's Avatar
Check it out someone is selling theirs quite a few miles on it though
https://www.evolutionm.net/forums/sh...d.php?t=249478
