Rear Diff???
Old Feb 5, 2007 | 01:31 PM
tseitz123's Avatar
Unhappy Rear Diff???
Crusing along today on the NJ Turnpike in fifth, doing nothing crazy. All of a sudden a crunching sound coming from the rear. I pull over and look under the car. Oil dripping (not pouring) out of the rear diff. I put it in gear and slowly let out the clutch. Moving now, but crunching/grinding sound coming from diff. Towed to TurboTrix. Any thoughts or ideas?
Old Feb 5, 2007 | 03:21 PM
DaWorstPlaya's Avatar
Was it pouring out of the drain hole/bolt area? Either way that isn't good ... Your rear diff might be toast ...
Old Feb 5, 2007 | 04:20 PM
tseitz123's Avatar
Oil coming from drain plug, i think
I am told that it is one of two things. It is either the pinion gear (stripped off teeth, etc.) or it is the diff. Now tell me, is this correct? Gears =$400+ Diff=$1100+
Old Feb 5, 2007 | 05:00 PM
scottatyamaha's Avatar
I take it that you are modded and warranty is not a option.
Old Feb 5, 2007 | 05:03 PM
DSMorBUST's Avatar
at least he was smart enough to have it towed and didnt drive it after the fact.. risking further, unforeseen damage!?
Old Feb 5, 2007 | 06:22 PM
tseitz123's Avatar
Warranty? HAHAHAHA!! Yea, and pigs may fly. I drove it about 1/4 mile to get it off the turnpike because AAA can't pick it up on that highway. But other than that.... Its either the diff itself or just the pinion gears. I hope its the latter.
Old Feb 5, 2007 | 08:19 PM
Impulsoren's Avatar
I doubt you will find a shop that will just replace the pinion gears if that is what is broken. The fact that all of those metal chunks were circulating throughout the rear housing makes all of the bearings and other gear teeth suspect. There are enough wrecked Evos out there you should be able to find a complete diff.
Old Feb 5, 2007 | 09:08 PM
tseitz123's Avatar
What exactly is in that rear diff case? I looked at Cusco rear diff's and they are about $1100. Is that about right?
Old Feb 6, 2007 | 12:23 AM
RoadSpike's Avatar
I have to wonder if the oil wasn't dripping before and the diff just seized before grenading on you. I guess that could have happened with a loose drain plug or some king of seal.
Old Feb 6, 2007 | 12:26 AM
blackbichGSX's Avatar
If you are looking for another stock Diff there is a whole one on ebay right now. FYI
Old Feb 6, 2007 | 07:50 AM
tseitz123's Avatar
send me link to that eBay rear diff if you would. I can't find it
Old Feb 6, 2007 | 07:57 AM
4WS Tuning's Avatar
http://cgi.ebay.com/ebaymotors/JDM-M...rdZ1QQtcZphoto
Old Feb 6, 2007 | 08:01 AM
tseitz123's Avatar
will this diff fit and work with my 2005 EVO 8?
Old Feb 6, 2007 | 01:23 PM
RoadSpike's Avatar
I don't trust Ebay for important parts like diffs and transmissions but to each his own. Did you crack the casing and this is the reason your considering this diff? If so I would spend the 4 dollars and shop around a pick N pull first for a casing and get one for probably the tune of 40 dollars.
Old Feb 6, 2007 | 01:34 PM
RazorLab's Avatar
If that diff has AYC it will not fit.
